07-01-2011, 02:29 PM | #1 |
Always a work in progress
Will a 315/35r20 on a 20"x10" fit in the rear?
I am looking for a fat tire and wheel combo for the rear of my truck. I have found a 315/35r20 that is a 27" tall tire, and a 20x10 with 5.5"bs. Do you think it will fit or will i have to widen the tubs?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
07-01-2011, 03:42 PM | #2 |
Re: Will a 315/35r20 on a 20"x10" fit in the rear?
that tire will be more than 12" wide
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
07-01-2011, 03:55 PM | #3 |
Tire Specs:
Section Width 12.6" on an 11" rim. Rec rim- 10.5-12.5" 28.7" tall not 27" I think it will be close, I read on here somewhere that they had this size tire on a 20x10 and it was close but they don't say if they modified the tubs or anything.
07-01-2011, 04:17 PM | #4 |
paper or plastic?
It will fit. I'm running a 20x12 w/6" bs. with a 315/35/20 lowered with a flip kit. I had to trim the fender lip about 1/2"
Just get your backspacing perfect!! Do a search with my user name for pics Posted via Mobile Device
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
07-01-2011, 04:19 PM | #5 |
I had 295-40's on 20x10 TT2's w/5.00"bs & then some Coy's w/5.50"bs w/approx 8" of rear drop . The 5.50"bs put the 295's pretty close to the inner tub wall. The 315's would come even closer since they are dimensionally wider but would still prob clear. I would imagine they would rub occassionally & you could always run a small .250" spacer to help (the 5.00"bs is ideal).
IMO, 315's need an 11" wheel minimum.
07-01-2011, 04:54 PM | #6 |
I have been thinking of a 20x12 as well but those wheels(Vintec) are a little more expensive than I wanted to spend. I really want the Vintec soft lip dish in 20x12 and 20x8.5 so i am probably going to just wait a little bit longer and get the wheels I really want. I am looking at the Eagle 225s that are a little cheaper but I don't like them as much as the Vintecs. I am not against adding some width to the tubs but I would like to keep the rear-end at a stock length. I will just have to wait until I get home and do some measuring to see what I can fit.
07-02-2011, 04:49 PM | #7 |
I'm currently running a 295/40/20 on 20x10 Boss 338s. I'm lowering the rig another 2 inches which will bring me down to 7.5 in the rear. I'll have to run a spaced and extended studs, shave the inside of the bed and inside of my fender to fit a 305/35...good luck Bro.
Posted via Mobile Device |
07-02-2011, 05:00 PM | #8 |
I am going to save for some 20x8.5 and 20x12 Billet Specialties SL Dish Vintecs.
07-03-2011, 08:37 PM | #9 | |
I need to see some pics of your set up, I am planning the same for mine
04-19-2012, 11:41 AM | #10 | |
Digging up an old thread...
Stock C10 10 bolt? Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
04-19-2012, 05:32 PM | #11 |
The Boss is 6.25" BS if I remember right. Showwheels have a 5.5" rear backspace, and we are running a special for April (10% Off).
http://67-72chevytrucks.com/vboard/s...d.php?t=517081 |
04-19-2012, 05:47 PM | #13 |
I already bought my Boss 338's for another project, or I'd be all over them.
04-20-2012, 03:58 PM | #14 |
Right on..... should look good on the truck, just need that spacer. The 305 & 315 look killer on these trucks.
01-01-2014, 02:33 AM | #15 |
I originally went with 275/40/20's on my Boss 338's, but they were bald within a year. I didn't like the tire stretched look anyway. I am using a set of 1.25" thick billet spacer/adapters to center the wheel in the housing and get the effective backspacing to 5.0".
Just bought a pair of 315/35/20's. They are mounted, balanced, and on the truck now. Looks like I might be rolling and/or trimming the inter lips to clear when hitting bumps. The truck is down until I complete the turbo setup. I thought about getting a set of 1.0" billet spacer/adapters in order to 'suck' the wheel closer under the truck since I have more room to move inside.
