Old 07-02-2011, 08:38 PM   #1
greasemonkey71
wont start
ok i just drove my truck from CO to san diego
was running a little rough when i finially got below 1000ft
so i rejetted the carb and now it wont start i checked the points and they are good
i really dont where where to check
the truck turns over it gets gas but it just wont fire
the spark plugs rotor cap and points we replaced at the same time about 2500 miles ago
greasemonkey71 is offline   Reply With Quote
Old 07-02-2011, 08:53 PM   #2
BMERDOC
BMERDOC's Avatar
Re: wont start
Points? Whats that? Ha, sorry, just kiddin. Comin down from the CO mountains to the sea shore I'd say you'd have to look over everything. K.I.S.S. Do you have spark? Uhmm, mixture. What do your plugs look like. Maybe your fouled. Let us know.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 07-02-2011, 09:08 PM   #3
greasemonkey71
Re: wont start
plugs are actually pretty good i was suprissed
Old 07-03-2011, 02:16 PM   #4
greasemonkey71
Re: wont start
yeah i pulled the #1 spark plug out and cranked the motor the plug wire stil attached and i saw nothing
Old 07-03-2011, 02:22 PM   #5
richards72chevy
richards72chevy's Avatar
Re: wont start
May be its your coil.I think most auto parts stores still test them.
richards72chevy is offline   Reply With Quote
Old 07-03-2011, 02:24 PM   #6
bosco200
bosco200's Avatar
Re: wont start
Do you have a HEI distributor?
bosco200 is offline   Reply With Quote
Old 07-03-2011, 03:08 PM   #7
Wrenchbender Ret
Re: wont start
Check the point gap. The rubbing block can wear down to a point that the points will not open. You need to put a tiny pinch or grease on the cam lobes in the dist.
Wrenchbender Ret is offline   Reply With Quote
