07-03-2011, 12:40 PM | #1 |
A day late and $1 short...
Any reason to keep these brackets?
Is there any reason to keep these brackets? I am going to use an LS/4L60 engine and trans.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
07-03-2011, 01:51 PM | #2 |
Still Just Havin Some Fun!
Re: Any reason to keep these brackets?
The first picture keep it. It will be part of your shift linkage. I'm not sure about the 2nd one.
a green one with some stuff done to it.... |
07-03-2011, 02:02 PM | #3 |
Thanks Kevin!
07-03-2011, 02:21 PM | #4 |
The second bracket is an exhaust hanger if I'm not mistaken.I used it and fabricated another for the pass. side when I made my Twice Pipes
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 |
07-03-2011, 02:23 PM | #5 |
PROJECT 7DEUCE
If your gonna run an aftermarket shifter then get rid of that 1st bracket..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-03-2011, 02:28 PM | #6 |
I am going to use a column shift set up with a 4L60E or 4L65E...
07-03-2011, 02:45 PM | #7 |
Watch out for your cornhole !
Even if you don't wind up needing it, the shifter bracket is worth money to someone on here who does need it.
07-03-2011, 03:20 PM | #8 |
Talked to Hart_Rod and he said I could remove it and use a Lokar shift linkage. I like that plan, it will open up that area for exhaust. Will put the bracket in my things to sell pile. Thanks for the input fellas.
