Old 07-10-2011, 03:03 PM   #1
trevor73402
trevor73402's Avatar
Exclamation Bench to buckets.....can I see your brackets please?
I picked up a very nice set of 6 way power leather buckets out of a late model GM yesterday. Im going to put these in my '84 K10 that currently has the stock factory bench in it.
Can you all show me some pics of the brackets that you've fab'd up and used in this type of conversion please. I have access to a welder and cutting tools so I can pretty much make whatever I need, but I was hoping to get a few photos and ideas here first to maybe speed the precess and not have so much "trial and error".
THanks guys,
****heres a pic of the sweet buckets i got.
1984 K10 SWB "Coal"
1987 K5 Blazer "Ole Miss"
1979 GMC Jimmy (Project)
2008 F250 CC 4x4 King Ranch 6" lift on 37's (Spartan-ized!!)
2008 Dodge Challenger SRT8 Hemi Orange
2008 HD StreetGlide
2007 HD Custom Fatboy
1980 Suburban (will be for sale or trade soon).
trevor73402 is offline   Reply With Quote
Old 07-10-2011, 05:56 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Bench to buckets.....can I see your brackets please?
SWEET is right
may need to see what they have below
I believe i've seen these type burb ones with the back bent up for the floor
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-10-2011, 06:48 PM   #3
80stepsideguy
Laid back freak
80stepsideguy's Avatar
Here are the seats im putting in my 80.
thanks
pat
1980 chevy c10 step side restomod,
1970 cougar convertible 1 OF 24 ever built:
2014 Hyundai Tucson limited (daily driver).
80stepsideguy is offline   Reply With Quote
Old 07-10-2011, 07:09 PM   #4
trevor73402
Hmmm.....
Well it looks like I may be able to use the two exsisting rails from the bench, but it looks like the inner two mounts will be custo-fab. The floor contour seems to be the same on the inner and outer section, so maybe if I found another set of bench rails I could use two per bucket and modify them to fit? I know more than two people have done this, it can be that big of a deal.....anybody else have any brackts they have fab'd up?
1984 K10 SWB "Coal"
2008 HD StreetGlide
Old 07-10-2011, 07:30 PM   #5
73gmc454
73gmc454's Avatar
heres what I made , I have the drivers seat mount but it was just to dark in the garage to get a pic
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 07-10-2011, 07:55 PM   #6
tucsonjwt
I have never done a bucket install in a square, just in a Honda Civic and CRX, but you will likely end up with a higher seat due to extra metal fabricated to adapt the new seats.
Maybe posting a shot of the bottom of the new seat will help get some ideas from the forum members.
Congratulations on getting seats with integral seat belts - now you can get modern belts and don't have to worry about making the old belts work, as long as your new seats are well secured to the floor. Considering the cost of recovering and rebuilding a stock seat, you made the right choice.
tucsonjwt is offline   Reply With Quote
Old 07-10-2011, 08:33 PM   #7
trevor73402
Ok, I'll take a few pics of the bottom. Ive found buckets before that were year/time correct for these trucks, but when I checked with the upholstery shop to have them rebuilt/recovered I almost fell out! It was insane what they wanna charge. Now, I have no idea how labor intensive upholstery work is, so the price may be justifiable, but it was gonna be close to $700 for them to re-do a set of low back K5 buckets that I was gonna put in the K10.
Here is a pic of the bottom of the drivers seat. Pretty basic, 4 holes. Right side is just tabs coming off the rail and the left side bolt hole is actually in the rail itself.
First thoughts are that it'd be easiest to just use the existing bench rail and weld the seat directly to it and fab up a match out of square tubing and add some tabs to bolt into the floor, then weld the other side of the seat directly to the fab'd rail.
1984 K10 SWB "Coal"
2008 HD StreetGlide
Old 07-10-2011, 08:33 PM   #8
trevor73402
1984 K10 SWB "Coal"
2008 HD StreetGlide
Old 07-16-2011, 10:30 AM   #9
vtwinsport
vtwinsport's Avatar
I cut mine out of a 88 suburban. works great in my 76.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 07-16-2011, 10:35 AM   #10
88Jimmy4x4
88Jimmy4x4's Avatar
thanks for the pic, do you have any more
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 07-16-2011, 11:29 AM   #11
BruthaMan
US Army Veteran
BruthaMan's Avatar
did the same as vtwinsport, took them out of a suburban.
BruthaMan is offline   Reply With Quote
Old 07-16-2011, 10:23 PM   #12
88Jimmy4x4
88Jimmy4x4's Avatar
sweet...Im waiting on my burb brackets now...only pieces Im lacking
thanks for the pics guys
1991 GMC Jimmy 4x4
Old 07-16-2011, 11:05 PM   #13
rayfinseats
Upholstery is very labor intensive. You have building rent, taxes, insurance, materials, labor costs, etc. There is cutting out the pieces, gluing the foam, sewing, removing the old covers, fixing the springs, foam repair, and then installing all the hog rings, screws, etc. THEN you have to make a profit on top of all that to pay your own bills. That price is not out of range that's only 350 a seat. The foam alone for truck buckets is $304 from Classic Industries.
http://www.classicindustries.com/truck/parts/14183.html
rayfinseats is offline   Reply With Quote
Old 07-17-2011, 06:47 AM   #14
88Jimmy4x4
88Jimmy4x4's Avatar
does anyone sell the foam for the high back buckets that came in a 1978 truck?
1991 GMC Jimmy 4x4
Old 07-17-2011, 10:51 PM   #15
rotgg
i found those seat are way to large for our trucks i would just try and set them in there before you even worry about mounts i know i have seen some use them but i have some in my shop and there was no way i could have used them and i am not that big
rotgg is offline   Reply With Quote
