![]() Join Date: Feb 2010
Silly queation
How in the world do you measure a driveshaft?
Posted via Mobile Device |
Re: Silly queation
You don't know, so its not silly. Measure center to center of the front/rear joints. If you have a slip yoke, IMO, you want about 2/3's to 3/4 engagement of the slip on the trans output.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
Re: Silly queation
If youre having one custom made ask the builder....with the suspension loaded take youre measurements ............ usually center u joint to center u joint .... last one i had done was end to end ..everyone is different
Re: Silly queation
http://www.dennysdriveshaft.com/how_to_measure.html
I printed this out, and filled it in when I had a driveshaft made locally...the driveshaft dude was appreciative. |
Re: Silly queation
How much of the nose of the drive shaft should enter my trans... Does it make a defference on length since it's a manual trans and not an auto
Re: Silly queation
I don't remember how much went in, because I don't remember how long the shaft is, but I've enclosed a pic of my old shaft, in the old 3spd...it looks like 1 1/8" of shaft sticks out, with weight on the suspension. My new driveshaft, in my new trans has about the same ammount of shaft sticking out.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Silly queation
My driveshaft shop has me bottom the yoke into the trans then back it out 3/4 of an inch. Then measure center to center of the u joints for length.
| Bookmarks |
