4.3L/700r4 to a 5.7L/700r4
I recently called my local transmission shop and got some info that I would like you guys to verify for me. I have a 4.3L and would like to put in a 700r4. Eventually I would like to put in a V8 such as 5.7L which I think is a 350. Would the 350 bolt to the 700r4? They said that the 700r4 would have a special bellhousing to bolt to the 4.3L but possibly would not bolt to the 350. Please let me know you thoughts on this.
Re: 4.3L/700r4 to a 5.7L/700r4
Sorry I forgot to mention the truck is a 94 chevy SWB.
![]() Join Date: Jul 2010
you should have 700r4 in it already & bolt up it will..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
Pop's I am doing a swap from a manual to a automatic. I was told on this forum that the best way to go would be the 700r4 so I don't have to mess with the electronics. So for know it will be joined with the 4.3L until I get a V8.
Ok..i got you..tha 4.3 is most circles a 350 with 2 less pistons.. both it will match up to tha 700..
Chevys Kick A$$
Yea I believe that both the 4.3 and the 5.7 will bolt right up to the 700r4 which would be a good choice to go with it your going to drop a 350 in it.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
The one fact that has been left out,make sure you aquire a V8 700,as the V6 version,while externally identical,is built with weaker components.
RIP Baby Jack 2-06-07 See You On The Other Side My Little Man |
Says who..that's like sayin a th350 from behind a 292 is weaker than a th350 behind a sb400.
Says me,who has built hundreds of transmissions.You can believe it,or not.Makes no difference to me.But I can promise you it's a fact.
| Bookmarks |
