Help Please!
Okay, so the line for my oil pressure gauge broke, I fixed that. In the process of fixing it though, I had to remove the distributor cap. After reinstalling everything, I started the truck to check for oil leaks and instead I came across a "ticking" sound while it was running. I tried driving it uphill (i live on a hill) and it started to "gallop" if I true going over 15 MPH. What could be causing this? My first guess would be that when I replaced the cap, I didn't align it correctly. All spark plugs, and electrical connections are exactly where they are prior to me removing the cap.
Posted via Mobile Device |
Re: Help Please!
Sounds to me like one or more of your wires aren't back on good, or you didn't get the cap seated right.
GM Parts Guy
Re: Help Please!
The ticking noise may be a wire arcing out. But thats just a guess.
1975 Chevrolet C-10 Custom Deluxe (DD/WIP) 1989 Chevrolet C1500 reg cab stepside (Winter Truck) 1977 Harley Davidson XLH 1000 (Summer Cruiser) |
78K & 79C Jimmys
Re: Help Please!
yup check the cap is seated and the wires are in and on all the way
make sure the clip didn't come/pull/break loose inside
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Re: Help Please!
if everything outside looks good, pop the cap off and check your rotor. may have loosened up.
2017 Tahoe Premier - Daily '99 Silverado 2500 Wife's whip- 2020 Equinox Premier |
Re: Help Please!
Okay, I pulled the cap off again last night and I think I got it seated the right way. How do I tighten the motor if it came loose?
78K & 79C Jimmys
Re: Help Please!
rotor ....two screws, either side.
Re: Help Please!
Thanks for now guys. I'm a go work on it and hopefully get it working right.
Re: Help Please!
Okay, I got the cap seated right and the wires all plugged correctly. I noticed though, that one of the wires was harder to install than the others, so I touched the boot of that wire so it'd make better contact with the spark plug and it zapped me. Could this wire be the culprit?
resident wrencher
Re: Help Please!
Yes it could be if you get bit by a wires id replaced it i had one time gone off road and pulling a hill i had the same problem you did the wire ad come off the plug on the head and gor me i took a scre driver or plies and adjusted the clip and made it stay tighter but it sound like you have an insulation leak there you can get single wires or a hole kit depends on what you want to do
Re: Help Please!
Okay. I'm a go pick up some new wires right now because according to me dad they were "replaced" along with the spark plugs, but its the same wires from when I first bought the truck.
resident wrencher
Re: Help Please!
Good idea
#13 |
78K & 79C Jimmys
Re: Help Please!
feeling the arc
yup good idea to replace em i assume it was running?when you felt it
#14 | |
Re: Help Please!
#15 |
78K & 79C Jimmys
Re: Help Please!
just makin sure sounded stupid to ask but wondered
#16 |
Re: Help Please!
It's alright, I'm halfway done installing the new wires.
#17 |
Re: Help Please!
Okay guys, I changed all my spark plug wires, took it out, got it halfway up the hill and she started spitting/galloping again.
#18 |
resident wrencher
Re: Help Please!
Check timing i had a simialr problem and wracked my bran i had no advance the mechanical weights were rusted stoped
#19 |
Re: Help Please!
#20 |
Re: Help Please!
Okay, so I checked the way I wired the plugs to the distributor with the diagram in my chilton repair manual and apparently I had 2 plugs wired wrong. This could also be causing misfires right?
#21 |
resident wrencher
Re: Help Please!
yes that def causes them if it still occours take the cap and rotor off leave the wires attachet to the cap the you grab the shaft or weigths were the springs are and see if the pivot and are free if not soak them in penatratin oil and see if ythey will break loose if not get a new distribtor make sue the lil springs are ok and there i know this is a pita for a 17 year old im 19 and just did this crap and it was a pita even for me being a mechanic some times all the hassel and frustraion gets the best of you
#22 | |
Re: Help Please!
#23 |
78K & 79C Jimmys
Re: Help Please!
he is thinking under the rotor there are weights
that advance and retard the spark by the vacume increase of the engine you may have seen them(look like half moons almost) he is thinking they might be rusted tight(mine were too) but it just made mine pick up slow....or slow to speed up but the two plugs wrong would make a big difference when right
#24 |
Re: Help Please!
Update: It idles fine, starts right up, but it only misses when I'm driving. I can rev it in park and its fine, but when I drive it, it misses.
#25 |
Re: Help Please!
Well I decided to "grow a pair" and took it for a drive around the block. She made it up the hill and around the block pretty easily. I did hear a scratching sound after I floored it on a straight away. Parked her in the drive way and noticed oil pressure dropped some.
| Bookmarks |
