Old 08-06-2011, 01:57 PM   #1
FLcustom10
Power Steering Pulley not aligned
This power steering pulley is sitting out about 1/4 inch further than the crankshaft pulley. Is this the wrong Power steering pump for 1972 307 ? Any ideas?
FLcustom10 is offline   Reply With Quote
Old 08-06-2011, 02:35 PM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Power Steering Pulley not aligned
Could the damper/balancer be drawn out a bit to make up the difference?
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 08-06-2011, 02:39 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Is your P/S pulley pressed on all the way? Is it the correct pulley? You might be able to use some washers between the crankshaft pulley and the dampener to space it a out a bit further.
Just some thoughts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-06-2011, 03:23 PM   #4
FLcustom10
I got the power steering pump off of e-bay years ago and I'm wondering if it might be for something newer than a 72. I'm afraid that if I use washers to shim out the crankshaft pulley it would make the alternator not line up, but I haven't tried it yet. I guess I should try it before I say it won't work. Are two single crankshaft pulleys an option instead of the double pulley?
Old 08-06-2011, 11:32 PM   #5
long69
i may not have the same bracket as you, but i noticed on mine that there seemed to be a way to adjust it with shims (washers) and maybe a hammer. but nothing to radical really. mine seems to be a stock cast one that mounts low and to the motor mount? mine might have been as much as a full pulley width off.
and mine use a 3 belt krank pulley.
long69 is offline   Reply With Quote
Old 08-07-2011, 12:53 AM   #6
darkone
i had a similar problem, this guy is a pro and helped me out big time. (thanks to the person who referred me to him) hes very knowledgeable and affordable! his phone number is in his ebay auction. give him a ring; http://cgi.ebay.com/ebaymotors/CHEVY...#ht_500wt_1182
darkone is offline   Reply With Quote
Old 08-07-2011, 03:55 AM   #7
Maxxd07
Maxxd07's Avatar
I am guessing the pulleys are wrong for each other or the pump pulley is wrong for that particular bracket. The factory didnt have to shim/hammer anything to get them aligned so thats my guess.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 08-07-2011, 03:07 PM   #8
long69
i was able to nicely adjust mine. just sayin'.
Old 08-07-2011, 03:30 PM   #9
rsavage
rsavage's Avatar
Is there a nut holding your power steering pulley to the pump? Looks to me like the crank pulleys are wrong ( at least the outer one). The one on my Burb which is the only non air set up I have, has a nose that fits against the first crank pulley and spaces it away from the inner about 3/8". The guy in the link "gotpulley" that darkone provided can definitely help you.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 08-07-2011, 04:15 PM   #10
Livrat
Member #1049
Livrat's Avatar
I see two issues.. that is the incorrect PS pump pulley and you do not have the crank pulley for PS. the crank pulley you have is for running the alternator and AC. there is a separate pulley for PS. (depending on which pump pulley it can either be a single groove stamped steel one or a cast iron double groove
Here is a picture of the correct "flat" PS pulley which uses the cast iron crank pulley.
http://67-72chevytrucks.com/vboard/s...d.php?t=474903
Here is a picture of the correct "bell shaped" PS pulley that uses the stamped steel single groove crank pulley
Scroll to post #7
http://67-72chevytrucks.com/vboard/s...d.php?t=474244
Livrat is offline   Reply With Quote
Old 08-08-2011, 06:40 PM   #11
FLcustom10
Thanks guys. I'm talking with Jim now.
Old 11-10-2011, 01:34 AM   #12
mo1968
mo1968's Avatar
Scroll to post #7
sorry nothing to see here made a mistake
mo1968 is offline   Reply With Quote
