Old 08-07-2011, 03:13 PM   #1
jbersaglia
Automatic Tranny Filter
I have a '94 Silverado Ext Cab 2WD and want to change the transmission filter and fluid. When I climbed underneath, I noticed the rear pan bolts are underneath the crossmember and the rear transmission mount is connected to the crossmember. Is there a way to get to the back bolts on the pan without removing the crossmember?
jbersaglia is offline   Reply With Quote
Old 08-07-2011, 09:19 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Automatic Tranny Filter
You can try un-bolting the trans mount from the cross member then from the trans and jack the tail shaft up off the member, But put a stand under the tail shaft or block of wood between the two before sticking your hand/wrench in to remove the screws.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
