Old 08-12-2011, 09:20 AM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Trailering Special?
My possible donor vehicle for my truck build is a late 70?'s suburban... Apparently its a "Trailering Special" with a 454. I need the 454 provided it's a 4 bolt block and I'm hoping it has a 12 bolt diff.. With the "Trailering Special" is it more likely that the 454 is a 4 bolt?
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi/3.42
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Ryan Brown Performance 850 Holley
Full weight long box pickup
Current best- 11.28@119mph
69GMC910 is offline   Reply With Quote
Old 08-12-2011, 03:37 PM   #2
cst70rocket
Re: Trailering Special?
Just wondering why do you need a 4 bolt block? The 2 bolt big blocks will handle more than the majority of the free world will ever throw at them. 700 plus hp on 2 bolt, if you get closer to 800 go with splayed caps, which will start with a 2 bolt block anyway.
cst70rocket is offline   Reply With Quote
Old 08-12-2011, 04:20 PM   #3
TJBrown
TJBrown's Avatar
I ran a 2 bolt 30 over 4.250 stroke cranked production 454 block im my dragster for a year or so. I used to twist it to 8k. Held together like a champ. 7.90's in the quarter. Not sure of the HP rating as i never had it on a dyno.
85 Silverado SWB
TJBrown is offline   Reply With Quote
Old 08-12-2011, 04:54 PM   #4
406 Q-ship
406 Q-ship's Avatar
2 bolt Big Block is more than strong for a regular truck.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 08-12-2011, 05:05 PM   #5
69GMC910
MOTORHEAD!
69GMC910's Avatar
Want this engine to last. It'll be 600+ hp and my engine builder has his heart set on a 4 bolt for some reason...
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi/3.42
Mark Williams Axles
Cal-Tracs
Old 08-12-2011, 05:06 PM   #6
69GMC910
MOTORHEAD!
69GMC910's Avatar
Maybe it's cuz we r stroking it??
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi/3.42
Mark Williams Axles
Cal-Tracs
Old 08-12-2011, 05:42 PM   #7
cst70rocket
eh 2 bolt is fine at 600hp level for ever. If he's concerned about strength, put splayed caps on it. I've ran pretty wild 2 bolt big blocks on nitrous up at 800hp level and no problems.
Old 08-12-2011, 07:50 PM   #8
ozark
Good luck on it being a 4 bolt main block. Most of all the 454's that came out of trucks originally(the ones I have gotten over the years anyway) have always been 2 bolt. Same with a steel crankshaft they have always been cast.
ozark is offline   Reply With Quote
Old 08-12-2011, 09:42 PM   #9
b454rat
All the 454s I've had came out of trucks, all were 2 bolt mains. One or two of them were in crew cab dually's, still 2 bolt.
If you just got to have a 4 bolt, then splay the caps, it's stronger than a factory 4 bolt. But I think it's overkill. I had a 500+ 468, spun to 7500 quite a bit, never a problem. Was even cast crank and small rods.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 08-13-2011, 12:29 AM   #10
80SPORT
80SPORT's Avatar
All the pickup 454s i have seen have 2 bolt mains;the early (73-74) units seem to have forged cranks ...later ones cast ...may have been when they switched to the peanut port head.
As a rule 4 bolt mains only came on square port hi perf car motors.
And on the tall deck medium duty motors
80SPORT is offline   Reply With Quote
Old 08-13-2011, 12:46 AM   #11
blakeduren
my 83 454 was a 4 bolt block.
blakeduren is offline   Reply With Quote
