Old 08-13-2011, 02:04 PM   #1
Alderson95
need help with 4l60e
i have a 1999 chevy c1500 new body style with the 5.3l. the trans in the truck just went out and i have a 1997 onle body style that has a good trans it has the 4l60e. my ? is will they sawp out.
Alderson95 is offline   Reply With Quote
Old 08-13-2011, 02:19 PM   #2
Alderson95
will a 97 4l60e swap with a 99 new body style 4l60e
my old 97 has a good 4l60e but my 99 has a bad one will they swap out thanxs
Old 08-13-2011, 09:24 PM   #3
66redw/white
made in america
66redw/white's Avatar
Re: need help with 4l60e
the old trans will have an extra bolt hole in the top that you wont use. other than that id think they would be a direct swap out. torque converters may be a smidge different. i couldnt say as far as anything else
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 08-13-2011, 10:00 PM   #4
Re: will a 97 4l60e swap with a 99 new body style 4l60e
In theory they should.. Are they both from a small block V8?
Old 08-13-2011, 10:07 PM   #5
Alderson95
Yes the 97 had a 5.0 vortec the 99 has a 5.3l
Old 08-14-2011, 07:51 AM   #6
speedygonzales
speedygonzales's Avatar
Since VCM's are different from year to year, the one thing that might be different is the connection. Can you look at them before getting the replacement to see if it matches your connector style?
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 08-14-2011, 10:41 AM   #7
truckdude239
truckdude239's Avatar
i am going say no
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-14-2011, 01:13 PM   #8
bighaas79
There was a change in I think in 98 that the pressure control solenoid went to pulse width modulated. Puting and older one in from a newer or newer to older will burn up the pcs. That and i think bellhousings were a tad different, as the ls series motor had a slightly different bolt pattern.
bighaas79 is offline   Reply With Quote
Old 08-14-2011, 01:16 PM   #9
bighaas79
Believe this is a double post so check my response in the other post.
Old 08-14-2011, 01:22 PM   #10
truckdude239
I merged your 2 post into one
David fuller
2000 Tahoe 5.3l 378
Old 08-14-2011, 02:40 PM   #11
Alderson95
Well i found out that the 97 4l60e is shorter than the 99 4l60e and the tork converter is smaller on the 97 than on the 99 thanxs for the help tho guys
