Old 08-22-2011, 01:04 AM   #1
dropped81
dropped81's Avatar
hmmmm rattle rattle...
Hey guys i was driving my truck tonight and i noticed a noise i have never heard before its a typr of rattle coming from the rear and its not my tailgate rattling...i know my pinion seal is bad do you think it could be the pinion bearing or could it be the carrier bearing...i dont know if i just noticed it because it was quiet outside or if it just showed up but i can also only hear it when im doing about 15-20 mph after that it goes away...any help would be appreciated thanks! Mike!
dropped81 is offline   Reply With Quote
Old 08-22-2011, 01:43 AM   #2
CrazyJesster
CrazyJesster's Avatar
Re: hmmmm rattle rattle...
just a thought i might be wrong could it be loose exhaust hanger?? or the spare tire hanger?? dunno just a thought
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842
CrazyJesster is offline   Reply With Quote
Old 08-22-2011, 02:36 AM   #3
dropped81
dropped81's Avatar
nah not the exhaust hanger i actully just had those rewelded a few months ago and i dont have a spare tire or spare tire hanger....also could it be a bad wheel bearing?
Old 08-22-2011, 05:25 AM   #4
Black 'n' Blue
Black 'n' Blue's Avatar
If you only hear the noise while going a certain speed, there's a 65% chance that its something in the drive line. I would check the wheel bearings, but I'm leaning more towards something inside the rear diff. From my experiences wheels bearing don't rattle they grind more.
-Justin.
The past cannot be edited, or erased. Only accepted.
Loud, proud and country by the grace of god!
Bradley Anderson 1997-2011
Black 'n' Blue is offline   Reply With Quote
Old 08-22-2011, 11:32 AM   #5
dropped81
dropped81's Avatar
ok so does it sound kinda like a pinion bearing?
Old 08-22-2011, 04:28 PM   #6
Fixwhataintbroke
Enthusiast
Fixwhataintbroke's Avatar
You can always jack the rear end up so both tires are off the ground, block the front tires, start the truck, put it in gear, have someone give it a little gas, and CAREFULLY look and listen to the back end.
- Cole
1979 Chevy C30 w/ carb 454.
1992 Chevy K1500 w/ tbi 350. *Sold*
1997 Dodge Ram 1500 w/ Magnum 360 *Sold*
"Good judgment comes from experience. Experience comes from poor judgment." - George Washington
Fixwhataintbroke is offline   Reply With Quote
Old 08-22-2011, 05:17 PM   #7
slammedLT1
slammedLT1's Avatar
If that seals bad who knows how much dust and dirt could be visiting the races of that pinion bearing and contaminating your diff fluid.
DIGGER
1984 GMC Sierra 1500 LQ4 T56 12B Chopped 2 1/4, Dropped 6/7, Shaved, Yenko Stripes
2004.5 CCSB GMC 2500HD DMAX LLY, 6" Liftmaster, 6 Fox Resi 2.0 325/50/22" Kumho A/T on KMW's LBZ MP, 5"Ex, Bullydog GT
1996 ECSB GMC Sierra 1500 350/4L60E, FL Headers, 2450 Stall, 6" Pro Comp,3" BL, Shock Hoops, , TrXus STS 38's
slammedLT1 is offline   Reply With Quote
Old 08-22-2011, 07:20 PM   #8
dropped81
dropped81's Avatar
hmmm ok i think ill try and change the seal and bearing here in the next few days anybody know if its a difficult process or not?
Old 08-22-2011, 10:07 PM   #9
slammedLT1
slammedLT1's Avatar
one thing thats for sure you need to set the proper bearing preload. did a quick search on google and found this http://www.differentials.com/install.html but someone on here can prolly give a more simplistic explanation for ya . I was always told a few crush sleeves come in handy when its goin back together if you dont't get the correct pinion depth. Can't be that crazy tho its just an old chevy rear end!
DIGGER
Old 08-22-2011, 10:11 PM   #10
dropped81
dropped81's Avatar
Thanks for the link LT1 ill be sure to read through it carefully!
Old 08-22-2011, 10:47 PM   #11
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
Prolly your rear axle mine went out cause the tards who owned the truck before me did tighten all the guts in the axle so it went had to get new gears
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 08-22-2011, 11:06 PM   #12
dropped81
dropped81's Avatar
if you dont mind me asking what did the guts run you price wise?
Old 08-22-2011, 11:15 PM   #13
383Chevy
383Chevy's Avatar
Depends on the gearing? i just stuck 3.23 in mine for now i got them for $20 and already had my locker from the old gears. what kind are ya lookin for?
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 08-22-2011, 11:24 PM   #14
dropped81
dropped81's Avatar
im not really sure what im wanting to put in the rear and im new to all this stuff so i dont know to much about rear ends or really anything to be honest with you...and recommendations?
Old 08-22-2011, 11:46 PM   #15
383Chevy
383Chevy's Avatar
3.73's new froms jegs is $203 and thats either yukons or richmonds but i would look around on craigslist should be able to find some on there cheaper
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 08-22-2011, 11:59 PM   #16
slammedLT1
slammedLT1's Avatar
Im sure if your pinion bearing is shot u should be able to get some play out of it by lifting up and down on the pinion. "Fixwhataintbroke" had a great suggestion to run the truck carefully on some jackstands and listen for any noise. Don't go buy gears with out inspecting whats in there first. Hopefully all goes well bud.
DIGGER
Old 08-23-2011, 12:39 AM   #17
dropped81
dropped81's Avatar
Thanks for all the help guys...
