Old 08-26-2011, 08:14 PM   #1
68c10owner
68c10owner's Avatar
305 carb on 350?
I`ve got a 83 c-10 with a 305. It only has 79k miles but it`s gutless. Was thinking about dropping in a 260hp 350 crate engine and reusing all my other parts. Are they calabrated different or will I be good to go?
Anthony
68c10owner is offline   Reply With Quote
Old 08-26-2011, 08:27 PM   #2
92GMCDriver
92GMCDriver's Avatar
Re: 305 carb on 350?
If its a quadrajet it should work fine. might need some adjusting but as far as i know the 305 and 350 had the same carb
92GMCDriver is offline   Reply With Quote
Old 08-26-2011, 08:37 PM   #3
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
I did the same thing... or my dad had the 350 dropped in, rather, but mine's an 84 with originally a 305.. had 400k on it.. it was tired, but everything form the 305 bolted right up to the 350.. intake, carb and all..
Matter of fact, I had to cut open the original air cleaner to let the 350 breathe..
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 08-26-2011, 08:45 PM   #4
68c10owner
68c10owner's Avatar
Thanks guys. I was going to do this swap on my old 84 before I sold it but my friend who is a GM master tech with 30+yrs said they are calibrated different adn the 84 was computer controled. I just don`t want to mess with much to install it.
Anthony
Old 08-26-2011, 09:04 PM   #5
CaliDude76
CaliDude76's Avatar
You really shouldn't have any problems... I have the ecu controlled carb, haven't had any issues since the swap..... it passes smog no problem, and runs great! Just have to run a lil carb cleaner thru it every so often.
CaliDude76
Old 08-26-2011, 09:17 PM   #6
Axle
Axle's Avatar
He is right on that count.
Will you notice? Probably not.
Alex.
Axle is offline   Reply With Quote
Old 08-26-2011, 11:13 PM   #7
rayfinseats
Dead on comment. You can always change jets if you have to.
rayfinseats is offline   Reply With Quote
Old 08-26-2011, 11:17 PM   #8
85crewcab
Metering rods if it's a Qjet..I seriously doubt if you will notice though.
85crewcab is offline   Reply With Quote
Old 08-27-2011, 02:41 AM   #9
68c10owner
68c10owner's Avatar
Thanks again for the info guys. Its going to be tax time at the earliest before i could do it. Been thinking of going with a 4.8 or 5.3 but my little 5.0 runs so good. You can barley tell its running untill I hit the a/c and it starts to shake a little but otherwise its as smooth as can be. Just doesn`t have much power and seems like Im always having to put my foot in it to get it going which sucks up the gas. Im thinking the 350 might get better mpg cuz I won`t need as much of the gas pedal to get going.
Anthony
