Old 09-08-2011, 12:09 PM   #1
into69z
"brand new second-hand"
into69z's Avatar
it's still leaking!!!
ok-I need help trying to find a leak. I have removed the chalk from the roof and replaced with the correct 3m seam sealer. I have painted the roof. I have replaced the windshield, installed and new Precision brand rubber seal and applied window sealer as well(all done by Safelite window repair) and I am still getting mositure in the glove box and I can see drips on the rubber mat inside the cab. Where would the water be coming from? any Ideas? The truck doesn't have a rust problem-it's been in Cali and Arizona all it's life except the last 5 months.
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 09-08-2011, 12:14 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: it's still leaking!!!
Sounds like a heater core leak. Does the moisture have the sweet antifreeze smell?
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 09-08-2011, 12:38 PM   #3
mpotts64
mpotts64's Avatar
could be the bushing to seal off the antenna cable is bad and leaking or could be the seam on the cab on the inner cowl leaking. If you look under the dash in the corner of the dash you will see a seam that runs down, it is actually on both sides, if that is rusted it will leak water there, have someone get under the dash and someone run a water hose to locate it. It could also be rusted out in the wire tray on the front of the firewall, or could be leaking around where the heater box mounts on the firewall, all of those places will put water inside the cab, best of luck
No one ever fell to the top of a mountain.
When asked why I work on old trucks, I tell them: Been married 27 years, sons are pretty much gone, don't like the wife anymore and don't have a girlfriend, so, gotta do something, the old trucks are cheaper and less drama than a girlfriend -
mpotts64 is offline   Reply With Quote
Old 09-08-2011, 12:45 PM   #4
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
At the lower corner of the windshield PS, and sitting just behind the cowl is a small seam on the body this is where the water usually creeps in and leaves puddles in your G Box.
See the link, we were discussing this not long ago.
http://67-72chevytrucks.com/vboard/s...ater+glove+box
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 09-08-2011, 04:55 PM   #5
AirSpeed
AirSpeed's Avatar
After I installed the new windshield and rubber in mine I noticed water on my floor mat, I traced it to the dash drains, the 1/4 hole in the corner of each side of the dash. It turned out the windshield rubber simply needed to be pushed towards the glass, it was barely on the windshield and was letting water pass and run through the drain and onto the floormat.
AirSpeed is offline   Reply With Quote
Old 09-08-2011, 06:34 PM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
have you tried using food dye to water and have someone pour it and you can try to find the leak with some white paper ,i used blue food coloring laid paper down and with a flashlite got under the dash and found the leak also i had the coolant system pump up with pressure to see if the heater core was leaking at the same time my brother pouring water
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-08-2011, 06:53 PM   #7
into69z
into69z's Avatar
Thanks for the link! I was beginning to feel left out......it seems I have a few places to check out to hopefully solve this problem-thanks again-Steve
Steve
67 Camaro
96 Impala ss-sold
b69:
