Mustang 2 front end?
can anyone tell me what the deal is with changing the from ends on the c10's to the mustang 2 front end? Is it worth it? what all do you have to do to make it fit? any help Thanks!
laying low
![]() Join Date: Mar 2001
Re: Mustang 2 front end?
I think it's a mistake to put a ponycar suspension under a 1/2 ton truck. JMO
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
its all about the +6 inches
About 6 years ago or so this cat came on here asking if thre was much interest. Most people feel that the front end under these trucks is good enough, becouse only a few people asked questions.
I was JW because I've heard a few people talking about this and couldn't understand why you would change it out.. my guess is that it is a cheaper set up to mod ..
it gives you rack and pinion steering, which offers you more feedback and less resistance to turn. That is the main reason to swap over. On other vehicles (60's & 70's fords for example) it allows one to get rid of the shock towers that make life hard when stuffing a big engine in a smaller car, and they are often rusted out anyways. Another common reason, on cars/trucks even older than that, is updating from a solid front axle. If you are swapping, may as well go for a common (lower cost) front end, and the mustang II/Pinto front end was a very good, low cost unit, that was (in it's day) very responsive and easy to adapt.
On a vehicle that is already independant front suspention, with a steering system that is considerably better than marginal, there is not much reason to swap. The thoughts of 'pintos/mustang II front end can't hold the weight of an old truck' isn't exactly a fair comment since these trucks arean't a whole lot more than a small block mustang II, and they front ends aren't simply swapped over, but modified first, or a kit that is BASED on the ford rack and pinion set up. |
1969 Custom 30 wrecker
Personally, I wouldn't want ANYTHING from a Mustang II on my trucks. And especially from a Pinto!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
