Old 09-15-2011, 03:06 AM   #1
72truckman
72truckman's Avatar
Snapped the U bolts and yolk on NP205
Power shifted into second gear yesterday, BANG. Broke the ubolts holding the ujoint to the yoke and really screwed the yolk up. Ill get some pics soon. Pulled the drive shaft and drove home in 4wd.
Anyone done a yoke on an NP205? any tricks/tips?
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 09-16-2011, 08:32 PM   #2
79k30dually
Re: Snapped the U bolts and yolk on NP205
Remove the nut, change the seal, install yoke, torque new nut, check fluid. good luck, Ron.
79k30dually is offline   Reply With Quote
Old 09-18-2011, 01:11 AM   #3
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Yep, broke mine too. Just simply remove the nut and the yolk comes right off. Mine broke half the yolk off of the transfer case and the one on the rear end broke an ear off at the same time. I just had to pick up my driveline put it in 4 wheel drive and drive off. No unbolting needed. I think i may need to upgrade these in the future.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 09-21-2011, 12:23 AM   #4
BlazinC5
BlazinC5's Avatar
Had that happen to me a few years back too. Bad part I was 2 miles across town and in a parking lot so the drivline was still hanging to the rear axle. And Just before I left my house I looked rite at my lil tool kit I had pulled out of the back of the blazer when I cleaned it out. Thinking Awww, what are the chances, I'll be rite back... Yeah, well after walking home in 90 deg heat and getting my neibor to give me a lift. I took the drivline off and limped home on the front..
71 2wd Blazer
My build, Restarted
05 Buell firebolt
94 1500 Z71
No rice for me,,, I'm full
BlazinC5 is offline   Reply With Quote
