Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-16-2011, 01:44 AM   #1
dbmx66
rack and pinion steering.
im switching to rack and pinion steering.
they have pinto or mustang manual racks. which one is better?
dbmx66 is offline   Reply With Quote
Old 09-16-2011, 09:22 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: rack and pinion steering.
Pinto usually has struts and is lighter setup (as in is for lighter cars) The Mustang II is a bit stronger from appearances. I'm not savy enough on chassis to say one is 'better' than the other for any reason.
If for no other reason than the weight of our trucks,, I'd consider the Mustang II
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-16-2011, 01:26 PM   #3
dbmx66
well mines gutted out pretty good. and the new engine im building has an aluminum block. so its only going to get lighter.
what i was wondering though, are the overalll widths of both the same or is on shorter? cause you and i both know these trucks are pretty wide hahaha
Old 09-16-2011, 03:43 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i would think there would be more parts choice for the mustang 2 .
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-16-2011, 07:40 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Porterbilt.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 09-16-2011, 11:13 PM   #6
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: rack and pinion steering.
Hmmmmm. That will be a Mustang II. Say no to Pinto's. Well there used alot in drag racing. I'm just a Mustang II fan.
http://www.rodandcustommagazine.com/...ion/index.html
Rack And Pinion Steering Conversions
http://www.hotrod.com/techarticles/h...g/viewall.html
Well I can tell you what I done on my '62.
Mustang II IFS Suspension (Manual Rack Steering) with 2" Billet Aluminum Wheel Spacers.
Heidts MP-042 - Superirde Front Coil-Over Shocks for Mustang II Suspension
Coil-Over Spring Rate (lbs/in) 500 lbs./in.
2” drop Spindles
58 Ford Wagon 9” Rear End (Axle Length 57.25 inches)
Wheelbase has been extended to 117".
Front wheels: Weld Racing Draglite 90-Series Wheel 15 x 7
Rear wheels: Weld Racing Draglite 90-Series Wheel 15 x 12
Front tires: Falken Visa 912 Tires - 758 P215/65R15 96H
Rear tires: Mickey Thompson Sportsman Pro Tire, 29x15.50-15LT
PROJECT: "FULL METAL YELLOW JACKET Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
I hate the torsion bar big heavy front ends of the 60-62 frames.
I am a big fan of Mustang II IFS & Ford 9" rear ends.
Most guys do this on thier Hot Rods, Street Rods, Cars and Trucks.
The most common 3 Front Stubs are - Mustang II IFS - Camaro - Nova Stub Frames.
But alot of guys are doing the bolt on later model stuff now on the '60's truck.
Now if you wanna research on Mustang II IFS you will be pleased to what you do find.
Mustang II IFS Systems are a natural conversion for your chassis, giving you a soft, smooth ride.
I could not afford a kit from Heidts or Fat Mans Etc...
www.heidts.com/
www.fatmanfab.com/
www.progressiveautomotive.com
So me and pops ran up on a 1976 Mustang II IFS (Manual Rack Steering) at a car show years ago.
The years are from 1974–1978.
If you go to a junk yard 99% of the time you will find that the front end is missing....
Now you know why. They are very very popular!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-17-2011, 07:48 PM   #7
dbmx66
i just gonna get the wilwood pinto setup. im going to take my crossmember out anyway to channel it for another 1.5 inch drop in front. since i lowered the rear more. so im just gonna weld brackets on to the front.
Old 09-19-2011, 09:37 AM   #8
team39763
Post up when you do it. I still haven't messed with mine. I got a pinto rack and 4th gen Fbody rack but I'm leaning toward using the pinto rack.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
