Old 09-18-2011, 07:00 PM   #1
Harley1650
1963 C-10 BBC/Muncie 4 spd
Harley1650's Avatar
Power disc brake conversion problems
I'll start by saying I'm not a master mechanic, so hopefully my problem is simple. I bought a disc brake conversion kit, a dual master cylinder and a 7" dual diaphram booster. I installed new brake lines, a proportioning valve and a Summit brand line lock to the front brakes.
The problem is.....
I have no leaks,bled it numerous times with a power bleeder and all I have coming out is fluid. The brake pedal goes all the way to the floor, but it does have some brakes at the floor.
The kit had no destructions so I was winging it. At the rear of the booster is a threaded rod coming out of the booster. When I made a new pushrod from the pedal to this rod, I connected it between this rod and the pedal so it did not engage the booster. I guess I'm wondering if I need to tighten the rod so it engages the booster?? I hope this doesnt sound confusing but I sure could use some help......
Harley1650 is offline   Reply With Quote
Old 09-18-2011, 07:08 PM   #2
Harley1650
Harley1650's Avatar
Re: Power disc brake conversion problems
Oh, and when I start it up the pressure is worse.....
Old 09-18-2011, 07:53 PM   #3
66GTO66C10
66GTO66C10's Avatar
Did the kit come with a small 2-3" rod? It goes between the booster and MC. It is a crucial part that will cause the symptoms you are describing.
Good luck!
1966 Chevy C10 frame off resto (In progress)
1966 GTO Numbers matching original
1989 Toyota Pickup (Tonka) resto
2002 HD FLSTC
2000 HD FLSTC
1996 Ninja ZX11
Believe nothing of what you hear, and 1/2 of what you see!
66GTO66C10 is offline   Reply With Quote
Old 09-18-2011, 08:14 PM   #4
Harley1650
Harley1650's Avatar
yes, theres a little @7/16 diameter @ 1" or so that goes into the master. I just took it off again and bench bled it (again). Now I dont have enough fluid to bleed them again. Boy, this has me baffled
Old 09-18-2011, 09:47 PM   #5
k1rodeoboater
Good luck!
Sounds like this to me too. OP it seems like yours may be a bit on the short side
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
