Old 10-06-2011, 08:57 AM   #1
srziemkowski
srziemkowski's Avatar
Glove box door mounting
Anyone have some pictures of glove box door mounting for 64-66,mine did not have one and recently got one from a member here and need to see what mounting hardware it uses to mount it. Any help would be appretiated.
srziemkowski is offline   Reply With Quote
Old 10-06-2011, 09:11 AM   #2
dthela
dthela's Avatar
Re: Glove box door mounting
hinge along bottom and two brackets that slide into slots in dash then screw onto door
dthela is offline   Reply With Quote
Old 10-06-2011, 09:27 AM   #3
srziemkowski
the hinges are still mounted on the door i got,just wondering what type screws hold the hinge to the dash
Old 10-06-2011, 09:34 AM   #4
chemlab
chemlab's Avatar
i used allen head bolts that i painted black, forget the bolt size tho... around 1/8 i think. same size bolt as the door pannels i believe.
chemlab is offline   Reply With Quote
Old 10-06-2011, 12:09 PM   #5
jimmydean
jimmydean's Avatar
I think they are smaller. I converted my door panels to use allens but the glove box uses some smaller ones.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-06-2011, 01:18 PM   #6
srziemkowski
I think im going to try this j nut and screw setup, i have a bin of some new ones. To mount the hinge to the dash on the sides of the box door.
Old 10-06-2011, 04:36 PM   #7
dthela
dthela's Avatar
takes 1/4-20 by 3/8 hex heads. should be weld nuts behind dash holes, retap them first!!!!!!
Old 10-06-2011, 04:37 PM   #8
dthela
dthela's Avatar
the screws that hold the brakets to the door have a flange built into them.
Old 10-28-2011, 07:58 AM   #9
dthela
dthela's Avatar
you're welcome
