ccsb questions
When you guys shorten your frame what do you do on the driveshaft?
Do you stay with a two piece or do you go to a one piece? Also when installing mid 80's suburban seats do you need any brackets out of the burb other than the tracks? Thanks |
Re: ccsb questions
anybody?
Re: ccsb questions
You will probably have to stay with a 2 piece drive shaft. Check with whoever is going to make or cut your drive shaft, but I believe if the drive shaft is going to be over 70" they recommend staying with a 2 piece. With a CCSB, yours should be over 70". Hope this helps.
#4 | |
Re: ccsb questions
I was hoping i could use a 1 piece, guesse i will wait and measure it after i get the frame done. Thanks |
Crew Cut
Re: ccsb questions
i used the 2 piece on mine, had to have the rear piece cut
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
Re: ccsb questions
Re: ccsb questions
Swapping burb/blazer buckets into a truck that had a bench seat does require inner bracket stanchions to keep the inside of the bucket seat level w/the outside. These could be made w/some steel plate bent up to the right dimensions or you can knock-out/cut them off of the floorpan from the donor vehicle.
#8 | |
Re: ccsb questions
Re: ccsb questions
i just cut my drive shaft down a few days ago, you cant go over 68"....i also am putting bucket seats in mine from a suburban. with the seats, i we just made some small brackets out of steel and bolted it to the floor..they hold up fine and look pretty good. do you have pics of yours?
#10 | |
Re: ccsb questions
I only have one pic right now, going to pick the truck up Sunday. Po had to pull the bigblock out, i putting in a 5.3 and 4l60e. I'll post up some pics when i get in Sunday night. |
