Old 11-01-2011, 05:50 PM   #1
EricS76
EricS76's Avatar
Brake Light Fuse Keeps Blowing
I've got a 1977 Chevy C-10 without cruise. My brake light fuse keeps blowing as soon as I push the brake pedal down. I've checked the wiring in the dash and it all looks good. Seems to me that if the problem was in the chassis wiring I wouldn't have turn signals and/or parking lights, but I still have those. Could it possibly be something wrong in the turn signal switch?? I checked the brake light switch and it's fine. Doesn't the problem have to be between the brake light switch and the point where the brake lights and turn signals are combined??
‘66 Chevy C-10, long bed fleetside, 350, 3 on the tree, 4-7 drop.
'77 chevy C-10 Custom Deluxe, 350, SM465 4 speed, flatbed.
'80 jeep CJ-5.
‘14 Chevy 1500 Z71…
EricS76 is offline   Reply With Quote
Old 11-01-2011, 07:48 PM   #2
kris's66lwb
resident wrencher
Re: Brake Light Fuse Keeps Blowing
Do you have trailer wiring i did and we played this game called bump where you tap each other car and my friend elco smashed up my trailer wires and caused a short and would blow my tail lamp fuse every time
I ALSO BELEIVE YOU LOOSE YOUR DOME LAMP AND CIG LIGTHER AS WELL MAYBE THAT WAS NOTHER FUSE IDK JUST KEEP IT IN MIND
kris's66lwb is offline   Reply With Quote
Old 11-01-2011, 08:15 PM   #3
john_p
yes, usually a pinched wire.. remove the fuse, and the light.. then test that wire to ground.. somewhere the bare copper is touching the truck.. that draws to much current, fuse blows..usually easy to find but that kind of trouble is my job..
if you do not have a meter, a test light, one side to battery, the other side to that wire will light the test lamp... using the brake wire as a ground.. IF you can not find the short, run a new wire.. cut it in half, replace the fuse and then press the brake.. now you know which half the cross is in..
john_p is offline   Reply With Quote
Old 11-01-2011, 08:17 PM   #4
john_p
if i can be of any help. leave a msg... 35 years a telephone man, pretty good with wires
Old 11-01-2011, 09:09 PM   #5
EricS76
EricS76's Avatar
I removed the power wire to my brake controller thinking that may be the problem but it wasn't. I think i'll check the trailer plug tomorrow too now JIC. John I will try your suggestions too. Thanks.
'80 jeep CJ-5.
‘14 Chevy 1500 Z71…
Old 11-02-2011, 12:01 PM   #6
EricS76
EricS76's Avatar
Well it turns out that the problem was in the turn signal switch connection. It had come loose from its retaining bracket and was touching the steering column.
'80 jeep CJ-5.
‘14 Chevy 1500 Z71…
