Hey, I just had my brother put a new clutch in my truck, I bought several parts to replace my old linkage parts..basically everthing from and including the clutch fork and up to the pivot on the frame. I did buy the parts at LMC but I thought they would work fine..the problem is my push rod, according to my brother is too short and it seems that the old one had a section welded on the end, is this a common problem or is something wrong. he had a mechanic but the clutch in. and i cant give any more detail for I have not seen my truck since christmass when the transmission and stuff was laying on the ground. Thanks for any suggetions and help
Displaced Canadian in Monterey California 1970 K10, 350 HEI, 4spd. 3.73's NP205 33"BFG Mud Terrains Edelbrock Intake and carb. 12 bolt rear,dana 44 front with disk brakes |
I am not sure what trouble you were having but there is different lengths of clutch release bearings and if you have a short one where the long one is needed then the clutch shaft will appear to be to short.
Jim |
