Old 11-11-2011, 12:39 AM   #1
69Beauty
69Beauty's Avatar
Backspacing. I know its a dead horse but it needs a good beatin!
I have a 69 c10 with stock width rear end. i am looking into getting some wheels vintiques 15x10 truck rallies (6 lug). they offer them in either 4.5 or 5 inch backspacing and i would like to run 28x12x15 mickey thompson s/r's with about a 2/4 drop and was wondering which backspcing would work best and what other guys are running.
Thanks in advance,
Logan
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers
1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles
1956 Ford F-100 Longbed with Original 272 and 3OTT
1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller)
1997 Dodge 3/4 ECLB V10 (MPG machine)
69Beauty is offline   Reply With Quote
Old 11-11-2011, 12:39 PM   #2
69Beauty
69Beauty's Avatar
Re: Backspacing. I know its a dead horse but it needs a good beatin!
anyone?
Old 11-11-2011, 03:56 PM   #3
hayhauler71
hayhauler71's Avatar
Just looked at them tires yesterday interested in your findings
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 11-11-2011, 09:01 PM   #4
SCOTI
SCOTI's Avatar
Thanks in advance,
Logan
1st, I recommend you measure your truck w/the current wheels to ensure things will work as expected (think of it as reverse engineering).
A 69 w/the narrower 6-lug housing could do both of the back-space dimensions listed @ the 4" drop proposed. When you start getting to the 6+ inches of rear drop, the back space limitations become much more critical.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 11-13-2011, 04:02 AM   #5
oldspowered67C10
Id go with the 5". On the shorter rear end(pre-70) ,with a fleetside bed, 5-5" backspace on a 10" wide wheel puts the wheel pretty much centered in the wheel well laterally.
oldspowered67C10 is offline   Reply With Quote
Old 11-13-2011, 12:28 PM   #6
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Coming from someone that has gone from 15.5 to 18.5 wide tires, you really need to make sure the wheels, but more importantly, the tires will clear. You need to know the cross section of the tire which is the widest part of the tire buldge. You can't go by tread width listed. The tire is widest at the center of the buldging sidewall and that is the part that will rub if too big.....not the wheels. I will tell you that if you have a coil rear, the inner wheel well is all you have to worry about. If it's a spring pack, I'm not sure if the springs become a problem before the wells will.
prostreetC-10 is offline   Reply With Quote
Old 11-14-2011, 04:04 PM   #7
69Beauty
69Beauty's Avatar
thanks for the replies guys. the tires are 12 inches wide while the tread width is 10.62 or something along those lines
Old 11-14-2011, 09:01 PM   #8
Mike C
Mike C's Avatar
The wheel wells on a leaf spring truck are the problem before the leafs. I have a '69 short step in the driveway now. It has 265 75 15 on the original wheels from my Jimmy. I want to do an axle flip in the back and go with 275 60 15 BFG drag radials. It looks like a 15x8 wheel with 3 1/2" BS would work.
I am probably going to mount the tire on one of my 15x10 Centerline ProTruck wheels as a starting point and see how much clearance I have. Will be interested to see what other responders say.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
