Old 11-11-2011, 12:17 PM   #1
Frank64
1953 Chevy Truck: my crazy project
Hello everyone, I'm new from Italy and I showed up in the area dedicated.
Let me share with you my project started as a joke but ....
Two years ago I bought a '53 chevy truck and everything seemed perfect until he got home....
Here are some photos...
Cab removing
Frank64 is offline   Reply With Quote
Old 11-11-2011, 12:34 PM   #2
Frank64
Re: 1953 Chevy Truck: my crazy project
Rust in the cab
Frame update: IFS Mustang II front end, Air Ride, Rear C-notch ......
Old 11-11-2011, 12:47 PM   #3
hopped up
hopped up's Avatar
feel like ive seen this build before? on another forum maybe?
hopped up is offline   Reply With Quote
Old 11-11-2011, 12:48 PM   #4
hopped up
hopped up's Avatar
not that it matters. sux to see such a nice looking truck hiding soo much!
Old 11-11-2011, 12:57 PM   #5
Frank64
Engine update: Removed his old 6 cyl and installed a new V8 350 Sb
Rear updates: Rear4 Link and Gm 8.5" 10 bolt rear-end
Frame painted
Old 11-11-2011, 01:04 PM   #6
Frank64
At the moment I am still here waiting for some parts and paint the body
Old 11-11-2011, 01:10 PM   #7
Frank64
Correct, but I do not know if you can say here...
Old 11-11-2011, 01:17 PM   #8
Fat Mike
Fat Mike's Avatar
Did your truck use to be a 5 window? Nice build so far!
Fat Mike is offline   Reply With Quote
Old 11-11-2011, 05:39 PM   #9
Frank64
This was a 5w and I turned into a 3w because I like the most.
If you change your mind in the future I can return to a 5w.
Many thanks.
Old 11-11-2011, 06:37 PM   #10
mknittle
mknittle's Avatar
Nice work!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 11-12-2011, 10:16 AM   #11
72Mountaineer
72Mountaineer's Avatar
Thanks for posting the great detailed pics of the Mustang II install. I am about to do this on my '53 and am a little nervous about the alignment, and the directions aren't great. Thanks again !!
72Mountaineer is offline   Reply With Quote
Old 11-12-2011, 09:05 PM   #12
solidaxel
solidaxel's Avatar
That was faster than T V time!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-13-2011, 03:33 PM   #13
Frank64
Hi, if I can be helpful to other more detailed photos please do not hesitate to ask. You can also write to: frank64garage@gmail.com.
Thanks. Frank
Old 11-14-2011, 10:55 PM   #14
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
welcome from one paisano to another.great looking build.i was in rome in july for vacation and a wedding in regio calabria were my family is from.keep the pics coming.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 11-24-2011, 05:24 AM   #15
ZUBZ
ZUBZ's Avatar
Frank lovely truck and build, keep the good work. Where can I get some whitewall/white-band tyres for my Chev C10?
ZUBZ is offline   Reply With Quote
Old 11-24-2011, 10:21 AM   #16
williamsboys
williamsboys's Avatar
That truck is looking so clean with all that chrome and loven the white frame. awesome build man good luck with the rest.
williamsboys is offline   Reply With Quote
Old 11-24-2011, 01:25 PM   #17
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
WOW! Looking killer! GREAT WORK.
--Josh
Old 11-25-2011, 03:55 AM   #18
OldskoolArtCustoms
OldskoolArtCustoms's Avatar
Go to www.speedwaymotors.com and it gives great instructions. Doing a 53 also. 18.5" from center of front shackle pivot is centerline for MII. I can fax em to u also buddy.
Oldskool Art Customs. "Done right the first time" 818-414-1968
OldskoolArtCustoms is offline   Reply With Quote
Old 03-29-2012, 10:47 AM   #19
Frank64
Hello guys,
my project continues and today I want to ask for your help.
As you can see in the picture I'm installing the windshield but I have problems to enter the stainless steel trim
Please can someone help me understand how to properly install this molding?
I ran all the information you find on the web but the gasket does not fit well.
Here in my city there is no one able to do this job.
Please, please, please, help me!!!
Many thanks
Old 03-30-2012, 08:59 AM   #20
solidaxel
solidaxel's Avatar
When we installed mine we did the rope trick which I see you have in place.
I do not see the S S on the drivers side, we placed the S S and the glass in the rubber gasket FIRST then the glass in the rubber and the rope in the inside bead,
We used lots of silicone spray and two people alinged the glass and rubber and started from the bottom lip and worked it all the way around the cab.
I did find that there are different types of gaskets, and by far the best one was from Steel Rubber Co. The other brand worked, but the rubber was much harder, and we worked up a sweat getting that one in !!
LS 3 4L70E
Old 03-30-2012, 03:38 PM   #21
Frank64
Thank you very much Solidaxel.
Tomorrow, I still follow your instructions, I insert in the rubber trim first, then insert the glass and silicone spray after.
This time I hope to install. My rubber from Counterparts.
Sorry for my english .
Many thanks
Frank
Old 04-04-2012, 12:59 PM   #22
Frank64
Hello guys,
I'm tired of trying, today was the tenth attempt....
with silicone spray was much better
I do not understand why remain open both corners of the rubber bottom .... as shown in pics
What should I do?
Many thanks
Old 04-08-2012, 05:07 PM   #23
AUSSIE54
AUSSIE54's Avatar
G'day Frank,
I like your little truck and what you're doing with it.
I don't have any ideas for your problem but would suggest that you might start a new thread in the 47-59 general discussion area with a title something like help with '53 Windshield Rubber or similar. More people may notice it there as a specific problem.
Regards,
Trently.
AUSSIE54 is offline   Reply With Quote
Old 04-09-2012, 05:11 PM   #24
Frank64
Smile Re: 1953 Chevy Truck: my crazy project
Originally Posted by AUSSIE54 View Post
G'day Frank,
Regards,
Trently.
Many thanks Trently, tomorrow start a new 3rd in 47-59. Thank you very much for you advice. You have a nice day. Frank
Old 04-11-2012, 10:16 AM   #25
jfortvalley
WHAT did you do with the bed wood after you notched the frame?
jfortvalley is offline   Reply With Quote
