L.E.D. dome light conversion kit
has anyone ever put l.e.d. dome lights in their trucks? if so how did you do it and how does it look?
my truck has been completely striped of a dome light and wiring im in need of one and want it to look legit and modern please help me i found a little something but im not to sure on how i would modify it to work in my truck http://www.stylintrucks.com/parts/un...0146_5762.aspx |
Re: L.E.D. dome light conversion kit
i got one in my 78 and its bright!! at least 5x brighter than standard and has a pure white almost blue tinge to it
officer,we weren't racing.. he was merely pacing me. |
you can convert any dome to led pretty easy.. 3 or 4 leds and a resistor .. radio shack has the parts, ebay has them cheaper.. if you have one that is to bright, solder in a 200 ohm resistor and cool it off some.. good leds cost under a quarter, same with resistors.. lot of how to help on line.. i'll be any help can
lmc sells one but would it go right on with factory wiring? where can i get the wiring harness and wiring diagram?
i would put it on the original wires.. your not drawing enough current to heat up the wires...
![]() Join Date: Jul 2010
most come with a adapter that goes in tha factory bulb spot & you plug tha led into it..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
You can readily buy drop in LED bulbs. NO need to buy resisters, and solder your own LED's together. The LED's you can buy at RadioShack are glass dome LED's and not the much newer SMD LED's. The glass dome LED's are dim compared to the SMD's. The old stock bulbs will look completely DIM compared to a good LED in there.
can you put a bright led in the cargo lamp? because that doesnt work either on my truck
what do you mean?
In the Forgotten far North.
![]() Join Date: Jul 2007
www.v-leds.com is where I got all my L.E.D.'s and my H.I.D.'s for my Suburban. My dome lights were a part # 211-2 for both the front and the rear like this...
![]() And this is what i replaced them with from v-leds.com 2 up front and one in the back,
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Those $8 Walmart dome lights are really bright. Thats what i used.
#13 |
what is the bulb # for the exterior cargo lamp for a 76
5 out of 4 people have trouble with fractions |
#14 |
I picked up a drop in LEd replacement from superbrightleds.com when I placed an order for LED's for my dash. It's nice, not stupid bright, but bright. I will be getting a new clear lens with my next LMC order. For my cargo light I picked up this eight inch strip of eight LEDs at Big Chain auto parts. It's cool, you can (and I did) cut it into two four inch strips. I did this and hard wired them in because my bulb socket was effed up. That worked very well.
I picked up some super cheap red 1157 LED bulbs off eBay for my tail lamps. They were total junk. Crumbled apart in my hands just trying to overcome the spring pressure of the socket. Superbrightleds.com isn't the cheapest around, but they sell a great product and they will get my business again.
Few things in life will make you look stupider than putting a dollar sign after a number. |
#15 |
Bonuscab,
Could you explain in more detail how you can cut the led strips and wire them up? I think that is my plan too.
1971 GMC 4x4 4 speed Project
#16 |
I used superbright LED's also. Great products. I thought they were reasonably priced vs other stores.
1985 GMC K2500. 350/TH400/208. 4:10's. stock. 1987 Chevy V30. 454/TH400/205 4:10's. Stock SOLD. |
#17 |
I looked for a direct replacement style panel like in the pic above (post #11) but couldn't find any. I used some small square panels & fabbed my set-up....
#18 | |
![]() Join Date: Oct 2014
As far as the Cargo light, once I replaced the housing, it worked. The housing was all rusty on the inside, so the bulb wasn't making good contact. |
| Bookmarks |
