Old 11-30-2011, 07:33 AM   #1
coralhead
coralhead's Avatar
need to buy a headliner retainer for rear of '50 AD
Is there any vendor or source for the rear retainer strip used on the headliner? I have not been able to locate one from any of the usual sources. Any help appreciated. Thanks
coralhead is offline   Reply With Quote
Old 11-30-2011, 09:44 AM   #2
youngrodder
youngrodder's Avatar
Re: need to buy a headliner retainer for rear of '50 AD
I have never seen them listed anywhere. I need one too and I was thinking of just making one out of stainless...I will make a cardboard template and mark the holes then transfer over to metal. Then bend, drill and cut.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-30-2011, 12:02 PM   #3
RLN THDR
The rear bow next to the dome light?
RLN THDR is offline   Reply With Quote
Old 11-30-2011, 01:55 PM   #4
youngrodder
Yes, that's the one...
Marc
Old 11-30-2011, 03:51 PM   #5
RLN THDR
http://www.ebay.com/itm/1950-53-CHEV...item2569f3e209
Old 11-30-2011, 04:12 PM   #6
youngrodder
Ouch for $100 I will make one...
Thanks though
Marc
Old 12-01-2011, 12:36 AM   #7
cajundragger
I think I have one. I have to look
cajundragger is offline   Reply With Quote
Old 12-01-2011, 01:19 PM   #8
coralhead
coralhead's Avatar
Thanks....Let me know
Old 12-27-2011, 11:43 PM   #9
cajundragger
this is pics of the one I have. you can see they have an S bend to them.
Old 12-28-2011, 12:16 AM   #10
mknittle
mknittle's Avatar
Is that the one that holds the front and rear together? I think there are two different ones in the middle. The early ones have a backer welded in across the the roof but around 51 it was deleted.
I was thinking about using one to support a overhead console for the radio in my 52.just passing a thought.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-28-2011, 12:25 AM   #11
cajundragger
no I think it goes at the back where the headliner meets the metal like right above the drivers head.
right? lol
I'm just guessing as my truck was apart when I bought it and I have a rod doors headliner.
Old 12-28-2011, 11:04 AM   #12
youngrodder
right? lol
Cajun-
What did you use on yours? Did your interior guy make one? I have a fiberglass headliner (simular to Rod doors) and am trying to come up with something for that strip.
Marc
Old 12-28-2011, 11:14 AM   #13
cajundragger
I screwed mine into the sheetmetal above your head and the front hooks into the the windshield trim. The sides press up against the sheetmetal "wings" that are above the windlace strips above the doors.
it works, Im not 100% happy but its good enough. I used stainless Phillips screws with the little trim rings around them in the back to screw it in.
I did 3m tape it in at first but a short run down the interstate with the a/c on (windows down) and it fell haha. scared the crap out of me.
Old 12-28-2011, 11:53 AM   #14
mknittle
mknittle's Avatar
I just went and looked the "s" shaped one goes in the middle to hald the front and rear panels together. There is a flat one across the back
Mark
My GMC build.
Old 12-28-2011, 12:42 PM   #15
cajundragger
gotcha. sweet.
Old 12-28-2011, 01:10 PM   #16
youngrodder
Thanks Cajun..
Marc
Old 12-29-2011, 10:04 PM   #17
cajundragger
yeah let me know what you end up doing. I have that bow if you want it.
Old 12-29-2011, 10:23 PM   #18
booger1949
hey if u do make one please put pics on here, i also need one an was thinkin of makin one myself
booger1949 is offline   Reply With Quote
Old 01-01-2012, 07:26 PM   #19
mknittle
mknittle's Avatar
found one page 16 use their page numbers not the one at the bottom of the page{pdf}
http://www.scribd.com/full/75817434?...ekaw0jyon6pa1h
the center one the hard one to make.
Mark
My GMC build.
Old 01-01-2012, 07:38 PM   #20
coralhead
coralhead's Avatar
I have a fiberglass headliner and one big tip on installation.....Do your fitting before installing the windlass around the doors. I had already installed the windlass and had a trying time getting the headliner in. I finally won.
Old 01-01-2012, 07:59 PM   #21
mknittle
mknittle's Avatar
did you fight it without help? You get extra points if you did you know
Mark
My GMC build.
