11-30-2011, 01:39 PM | #1 |
Carb issues, to Holley or not.
We got into my truck yesterday and made some good progress. I discovered that I have a Rochester 2 Jet carb which is clearly not original due to the couple of vacuum hoses that I found plugged with twigs. Yes, tree branches, not even a proper dowel.
In any case, the Rochester is unhealthy and the choke linkage is locked up anyhow, and the choke cable broke, oops. Anyhow, I went over to Jollys6066 page and read about the Holley conversion. It's a bit expensive but I'm considering it. It seems I might need a couple of other things like an air cleaner and a fuel line adapter which will add to the price. What I want to know is if anyone has found any cross over parts that would be cheaper (air cleaner or a mod) or wants to recommend a reliable carb rebuilder where I can get a rebuilt Holley cheaper. Or if anyone has a Holley for sale? PM me. |
11-30-2011, 02:16 PM | #2 |
Re: Carb issues, to Holley or not.
I sent my rochester back to Holley to have rebuilt. Even came w/a warrenty.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-30-2011, 04:16 PM | #3 |
Interesting...but aren't I better off having a proper carb with all the appropriate hookups? It seems this particular Rochester is missing something.
11-30-2011, 04:50 PM | #4 |
A little more info would help. What engine? What intake manifold? are you staying with 2 barrel Or going to 4 barrel.
11-30-2011, 05:35 PM | #5 |
Sure, truck is a 1966 GMC long stepside with 351V6 and I would stay with a 2 barrel. Sorry, can't tell you what intake manifold it appears to be stock otherwise.
11-30-2011, 06:29 PM | #6 |
Senior Enthusiast
If it were mine I would do the swap. The original carb offers little in the way tuning, whereas the Holley can easily be adjusted to provide superior operation. Post #30 on the attached thread begins a step by step conversion to the Holley:
http://67-72chevytrucks.com/vboard/s...=354432&page=2 I’m no V6 expert but I believe the 60-61 intake manifolds ran a one barrel carb, so when swapping to the 2 barrel Holley the later manifold you already have should be the sought after version. |
11-30-2011, 07:37 PM | #7 |
Check the base & bolt pattern. There are not a lot of different carbs that will fit that.
11-30-2011, 09:41 PM | #8 |
You need to buy an adapter and the holley 500 should fit. heres one for sale locally.http://visalia.craigslist.org/pts/2686985411.html
12-01-2011, 04:58 AM | #9 |
Thanks Andyboy!
12-05-2011, 09:13 PM | #10 |
choke cable
Guys, another Noob question. I ordered up the Holley 4412 and I need a choke cable. Is it universal or is there one specific to my truck?
12-05-2011, 09:20 PM | #11 |
They are pretty much generic, although you might want to get one with the correct knob for your truck from LMC or the like..
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
