How low should I drop the rear?
I have installed coil springs only in the front to drop it 2inches.
Do I need to drop the rear 3inch or 4inch w/coil springs to make it look leveled? Rear tire is a 295 / 50 / 15 and front is a 235/ 60 / 15 |
Re: How low should I drop the rear?
I usually go with the assumption that the rear is 2" taller than the front.
Your fronts are 26.1" tall Your rears are 26.6" tall If it was me I would lower the rear 2" more than the front in an attempt to achieve a level stance. Every truck is different so I would also measure the height of the rear wheelwell to confirm this. Also keep in mind that if your truck has the original springs in it they may already be sagging. Meaning You may already be lower than stock, so when you install drop springs you may not achieve the drop you want.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#3 | |
![]() Quote:
Posted via Mobile Device |
Grandpa in the rustmobile...
These trucks have a rake, the rear is 2" higher. (roughly)
So if you wanted to make it 'level' with a 2" front drop id put a 4" drop spring in the rear
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Yeah. Keep in mind (ive always read this) that your 40 YO springs have probably sagged noticablly lol
![]() ![]() Join Date: Jan 2011
If you go any lower than 4" drop in the rear you'll also want to consider shock relocation and adjustable track bar. So that might help with the decision.
Also, LWB or SWB? Measure your pinion angle before and after so you can get it back to spec. Chances are you'll be fine with a 4" drop but to save your Ujoints and just overall 'correct-ness' I like to put it back to 1-2deg at the pinion.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#8 | |
