Old 12-22-2011, 10:41 PM   #1
Arellano75
Boss 338 w 255/35/20 & 275/35/20 tires
Well finally became a member, so hope this helps me out with all the questions i have. The main question i have is, that i have a 71 stepside, and when i was in iraq my wife bought me the boss 338 wheels in black. After all the research i did, "yeap" they are still having issues with them. Seems like once you paid for your wheels, they really don't want to deal with you. So thanks to this web-site, i found out that the only way to make them fit is to turn the hub on rotors. Well, i ran it over to my buddies house, he looked at me like i was crazy, but it sure was alot cheaper to go this route than having to send them back. Anyways my question is, will a 255/35/20 & 275/35/20 combo look good on this truck if i have 20x8.5 (f) & 20x10 (r). It is a daily driver but i just go to work and home. Jobs is about 12 miles round trip m-f. If anyone can answer this and maybe send me some pics that would be awesome. Here are some pics of my truck. "work in progress".
Arellano75 is offline   Reply With Quote
Old 12-24-2011, 12:09 PM   #2
fishingjred73
fishingjred73's Avatar
Re: Boss 338 w 255/35/20 & 275/35/20 tires
You might want to get a mod to move this to the 67-72 discussion area or the suspension area to get a answer.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 12-24-2011, 12:23 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Welcome to the board.
I have requested a Moderator to move this thread to the 67-72 Message Board area.
You accidentally posted in the FAQ (Frequently Asked Questions) Area.
Great looking truck.
You are correct about the front wheels still not fitting without a few mods.
Those wheels will look great on your truck.
I personally am not a fan of 35 series tires,... but they will work fine.
Have you test fit the rear wheels?
You may need a spacer to keep them from rubbing the bedsides.
They have a 6.225" BS,... so most likely they will rub.
Keith
Convert to disc brakes.
Old 12-24-2011, 12:58 PM   #4
Arellano75
Lolife 99... As you can see all this is new to me, so that's why i posted on faq.
As far as a test fit is concerned, that is a negative. I was too wrapped up with the front hubs that when it came to it i just didn't bother with it. From everything i have read, it looks like i will be needing a spacer out back. No biggie... All the research i have done, it's probably better if i go with with like a 245/45/20 or 255/45/20 up front and probably a 275/45/20 out back.
Old 12-24-2011, 01:19 PM   #5
lolife99
lolife99's Avatar
I suggest a 40 series tire.
Just right in my opinion.
Keith
Old 12-24-2011, 01:26 PM   #6
fishingjred73
O Yeah Welcome!
Here's another thread that's a pretty good read with some links. http://67-72chevytrucks.com/vboard/s...d.php?t=482381
James
Member of
Old 12-24-2011, 01:48 PM   #7
Arellano75
Thumbs up Re: Boss 338 w 255/35/20 & 275/35/20 tires
Thanks for the help.....
