60-62 and 63-66 column differences
I've started my search for a 60 automatic column and need to know what the differences are in the years. I've heard a change happened between 62 and 63. Is it looks, fit, or function? Will a 63-66 bolt in my 60 and fit fine?
1961 crewcab
Re: 60-62 and 63-66 column differences
short answer- no
but you can make one work the bolts that hold the housing to the brake pedal support are in different spots. the turn signal controls were different through the years, I think the breakdown is 60-62, 63-64, 65-66 as a result the turn signal cups attach differently, and the tops of the column housings are different. if you need to piece a column together, you will need/be better off if you can find a complete one , or parts for the specific year you have. IF, say you find a complete 65 auto column, you should be able to re drill the mounting holes, and make it fit. I suggest finding a 65-66 colums, because those are the ones that have the most common replacement parts.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
![]() Join Date: May 2007
Not 100% sure but I think one of the differences is the wire connector is different.
There's a local yard here that has a 61 with a auto column in it. It would need to be rebuilt and it is missing the shift indicator.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
What about looks? Is the physical appearance different from the driver's seat between the different years?
I'm willing to rebuild one, but it's too far away to get. Unless the local yard is willing to ship???
