Old 12-23-2011, 10:47 PM   #1
68350
68350's Avatar
Starter power help
I know this is a post about a 79 but this side gets way more traffic and I might get a faster response...
So I just installed a standard column in my 79 GMC. It was once converted to a 4 speed from an automatic. I got everything all hooked up and what not. Went to start it and it has full power except it doesn't turn over. Lights, buzzers, radio and everything works as it should, just doesn't start. No clicking or anything on the starter. Any help as to what wires to check for power or ? thanks
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 12-23-2011, 10:55 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Starter power help
Might be something with your old Neutral safety switch.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-23-2011, 11:05 PM   #3
68350
68350's Avatar
99% sure it wasn't hooked up when I pulled the auto column
Old 12-23-2011, 11:28 PM   #4
ls1nova71
ls1nova71's Avatar
That.means there's a 1% chance its your problem. Look under the dash for the plug with 2 terminals and usually a purple and yellow wire in it( sometimes two purple) and make sure its jumped between the terminals.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-24-2011, 11:09 AM   #5
67Slider
67Slider's Avatar
Had an issue like that. Ended up a round issue. Check all your ground and clean them up.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 12-24-2011, 12:39 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If the column is all that was messed with, and it started before, then forgrt the grounds.
Double check the neutral switch.
Check out the tumbler and the actual ignition switch.
Old 12-24-2011, 07:58 PM   #7
68350
68350's Avatar
thanks a bunch guys, it was the neutral safety switch, plugged it in and fired right up. Now the headlights dont work? They worked before I hooked up the safety switch, but I think it might be the dimmer switch. Dang wiring demons from past owners...
