Electric Fan Question
i am taking the flex fan off, heard too many bad stories. what kind of cfm do i need from a fan to cool a 350 hp motor. any suggestions of what type of fan to use. iheard spahl fans were good.
i aslo heard that 95 and above ford tarus fans were good too. i dont know need help |
use a early 90's nissan maxima or altiam fan. i put altima fans in mine. they are actually mf'd by a good company out of georgia. It's a dual fan setup that fits over the raditor PERFECTLY. i can get some pics of the setup if you want.
Post Whore
![]() Join Date: Feb 2000
Please post some pics!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
i would also like to see some pics.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
fans i have more pics tell me what you want to see
Post Whore
I'd like to see a pic of it as mounted on the radiator if possible.
For starters how about how the look in the truck and not the nissian logo....
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
sorry man wrong pic better now?
gmc67swb gave me one that looks just like that. I have been trying to figure out what it came out of. I mounted an angle where the old shroud mounted at the bottom. I drilled two holes in the angle for the "pins" on the new fans. I can not believe how good the fit is. It fits PERFECT. One of the ears on top is broke off and I would like to get another one just like it. Also want one for my 68.
Seasonal Poster
How do you even go about wiring up an electric fan setup? I wouldn't mind trying it some day...
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
these are very perfect fans for these trucks.... i had no idea how well the fit was going to be. i just measured side to side and top to bottom and found a match. Brought it home and it was perfect. I can draw up a wiring diagram and a list of parts for any one who would like. If you cant find a set of fans i can find one in a yard down here and get it to you for gas+shipping+fans. I get 9.5 mpg and its 15 miles one way. pay upon delivery of course and ill include the yard recipt. Most yards sell them for under 50 bucks. My set was 35 with a cracked shroud that i fiber galssed later.
Seasonal Poster
#13 |
Location: Bondurant, IA but in Worcester, MA for school
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
#14 |
I'm using a mid 90's Crown Vic fan. Here's a picture.
#15 |
did the altima fan have two "pins " on bottom and two "ears" on top?
#16 |
affirmative will. you've got altima fans. the maxiam fans have ear top and bottom. they are a bit harder to intall but i have done them too.
#17 |
more that dman nissan pic keeps showing up ... it's one for good now.
#18 |
both of those holes are round i dont know why that one looks square. also, you have to notch the angle aluminum. I can put more pics of the top and bottom notched segments if you like. I'm working on a wiring diagram right now.
#19 | |
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
#20 |
I mounted a flex-a-lite black magic fan into the original shroud, works great...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
#21 |
BTW these fan setup cost about 50 bucks fully installed. less if you got your fans free
![]() Last edited by Jackal2k9; 04-23-2003 at 08:51 PM. |
#22 |
Do I just ask for a 30 amp relay at the parts store?
#23 |
30 amp 12v single switch relay. At the Orielly here they sell them as off-road lighting relays out on the shelves. Check there first. Otherwise you might have to go t an eletronics outlet (maybe radioshack) and get one there.
#24 |
67-72 Addict!
Jackal2k9, you have a PM. Thanks guy!
Any detailed pics and a little write up would be a huge benefit to members on the FAQ forum if you get a chance.......Jim
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 04-23-2003 at 09:52 PM. |
#25 |
"Trucks with Class"
![]() Join Date: Jul 2000
Pic lightened up a little for better detail.
