Bogs off idle, any ideas?
When I press the throttle it has a BIT of hesitation. Any ideas on how I should tune the carb? It's an untouched Holley 4160 600cfm Electric Choke/Vacuum Secondaries. I think I have it pretty lean at idle, should I richen up the idle? Thanks guys!
Signals in the bumper.
If its boging at idle, I would have thought that that meant it was too rich.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
It followed me home?
I have an edelbrock, dont know if its the same as yours but I had to get diffrent metering rods
A bad EGR valve will also cause a slight bog off idle.
If you have an EGR try to unhook the vacuum line and plug the line, then take it for a cruise. If it acts fine now, then its your EGR. If it still does it, its probly carb or timing related.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
#5 | |
It may NOT be the EGR. I suggest you test it.
| Bookmarks |
