camaro front clip? or camaro?
i found a 77 lt camaro will this front clip work i dont know the cut off year for clips or i found a 74 nova witch is better ?
Re: camaro front clip? or camaro?
Camaro 70 to 79 all the same, it will work fine...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
yep, and it'll revolutionize the driving of your truck. here's a few pics of mine.
and no snide remarks about my leaky valve cover gasket. Fel-Pro blue stripe, lasted '85 to 2011. Not bad, IMO. fixed now. right side is still clean and dry. at least 200K on that engine.
That will work fine for the swap.
here is a link to a thread on the HAMB that Lux Blue did that has become one of the go to threads on this swap on the net. http://www.jalopyjournal.com/forum/s...d.php?t=148978 He walks you through it step by step and he has done a lot of them in his shop over the years. |
The Nova is 2 inchs narrower than the camaro,also Nova is rear steer camaro is front steer.
should mention, frame is plated inside back to about the cab mount.
part of the reason it drives good is the 1.125 front sway bar and the 12:1 WS-6 T/A steering box. Recent addition of C4 Vette rear really helped too. this thing drives like a go-kart. |
no shortage of opinions here. the early rear steer Nova clip AFAIK is the same as an 67-69 Camaro. Problem with these is that it has short spindles like a 64-72 Chevelle. This means the front roll center is several inches below ground level. The later Nova and Gen2 Camaro has a tall spindle design which places the roll center about 4" above ground level. Inherently better handling deal.
#9 | |
Glad to see....
I jest can't stand no pristine, spottless trailer queen.... reminds me to much of my second wife..... justplainray |
I used for a mobile mechanic work truck for years, stoplight to stoplight in Phoenix in the summer. That's hard miles.
