Old 01-04-2012, 11:28 PM   #1
olblue81
olblue81's Avatar
6L80E questions
I just picked up a 17,000 mile 6L80E from my insurance company out of a 2007 2wd Sierra. It's going into my 1981 GMC someday but I've got some questions that so far I haven't found answers on here for.
1. What yoke does the trans need? I'm unsure what yoke I'll need to run and the trans didn't come with one. I'm supposing my best bet is to order one from GM for the truck the trans came from and have a new driveshaft built with 3/4 ton u-joints. But if I do that, how am I going to mate it to the 12 bolt rear?
2. I picked up an ECM (PCM) from them as well. They said that it mounted near the battery on the donor truck. But I've read on the net that the ECM is internal in the trans. Anyone confirm that there should be an external or internal ECM?
Thanks.
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
Old 01-04-2012, 11:47 PM   #2
olblue81
olblue81's Avatar
Re: 6L80E questions
Ummm, I'm not sure I have a 6L80E like I was told. I was looking on gmpartsdirect for a yoke and it shows a 6L90E for the application. I'm going to have to measure the length of the tranny to find out which one I have now.
Stu-
Old 01-05-2012, 12:18 AM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 6L80E questions
The Transmission Control Module (TCM) is in the pan of the trans. No one makes a stand alone controller for them yet so you need a 08+ 58x crank LS style engine to run it. This is pretty much all I know about them, hope it helps a bit.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-05-2012, 12:21 AM   #4
olblue81
olblue81's Avatar
Re: 6L80E questions
I wonder what module they sold me at the insurance co?
I'm looking for 08 up motor. I've been told the new body style 07 trucks had the 58x crank sensor. This tranny is from an 07 so that makes sense.
Stu-
Old 01-05-2012, 12:27 AM   #5
usmcchevy
usmcchevy's Avatar
Re: 6L80E questions
07 being the change year I thing you have a chance of ether Mine is a 07 (van) and is a 24x.
Build thread
LSx Swap FAQ index
Old 01-05-2012, 10:43 AM   #6
olblue81
olblue81's Avatar
Re: 6L80E questions
I've been told it has to be an 07 new body style (GMT900). Is that what yours came from? Or was it the 07 Classic style?
Stu-
Old 01-05-2012, 11:49 AM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 6L80E questions
Vans and trucks are different as far as the motors, the older motors seem to had been used in the vans more. like in 03, trucks and SUV's went to the DBW throttle body, the Vans were DBC for another 2 years, so that pattern seems to continue as far as the reluctor. I am no expert just spewing what I have read.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-05-2012, 11:51 AM   #8
usmcchevy
usmcchevy's Avatar
Re: 6L80E questions
Vans didn't get the 58x until 08, I was just making sure you knew they used both in 07. You're on the right track.
Build thread
LSx Swap FAQ index
Old 01-06-2012, 08:41 PM   #9
usmcchevy
usmcchevy's Avatar
Re: 6L80E questions
found some info here: http://ls1tech.com/forums/conversion...does-go-2.html
Build thread
LSx Swap FAQ index
Old 01-06-2012, 10:45 PM   #10
olblue81
olblue81's Avatar
Re: 6L80E questions
thanks!
Stu-
Old 01-08-2012, 01:11 AM   #11
Mr. 250r
Mr. 250r's Avatar
Re: 6L80E questions
Well 3/4 u-joints could possibly be 1410.... which are quite a good size my new 2005 FF axle came from a 3/4 and has a 1410 u joint so i need new driveshafts because they do not make a jump joint from my old one to a 1410 as far as mating it to the 12 bolt rear end i couldn't find a 1410 style yoke for that diff so you could try a 1310/1350/1410 depends on what your tranny yoke is
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 01-14-2012, 07:33 PM   #12
olblue81
olblue81's Avatar
Re: 6L80E questions
Thanks for the info. I did a quick google a week or so ago and found that there is a 1350 yoke available for the 12 bolt. Still unsure what the tranny yoke will be.
Stu-
Old 01-14-2012, 07:49 PM   #13
Mr. 250r
Mr. 250r's Avatar
Re: 6L80E questions
if you read this build http://ls1tech.com/forums/conversion...ng-hauler.html look for post #8 it says the 6l80/90 uses a 1410 so the way i understand it is he did have one built with a 1410 on one end and a 1350 on the other which is an option you could try which shouldn't be a big deal for a drive shaft maker
2003 1500 Silverado
Old 01-14-2012, 08:56 PM   #14
olblue81
olblue81's Avatar
Re: 6L80E questions
Thanks for the link!
Stu-
Old 01-27-2012, 08:24 PM   #15
effects66
effects66's Avatar
Re: 6L80E questions
Actually they do make a stand alone controller for all GM trannys, including the 6l80e. TCI makes it.
effects66 is offline   Reply With Quote
Old 01-27-2012, 09:02 PM   #16
usmcchevy
usmcchevy's Avatar
Re: 6L80E questions
http://www.tciauto.com/tc/tcir-ez-tcutm.html
"TCI EZ-TCU-Compatible with most popular GM transmissions, including the 4L60E, 4L65E, 4L70E, 4L80Eand 4L85E, as well as the TCIŽ 6x Six-Speed Transmission"
The TCI 6x is a 4l80e with two more gears, not a 6l80e unfortunately.
http://www.tciauto.com/tc/transmissi...-1.html?main=4
Build thread
LSx Swap FAQ index
Old 01-30-2012, 05:01 PM   #17
olblue81
olblue81's Avatar
Re: 6L80E questions
My plans are for a Speartech harness and PCMs. Not the cheapest out there, but it's complete and easy. Honestly, I'm pretty sure he just buys it from GMPerformance Parts and tunes it, but that's fine with me.
So now I'm just hunting for an engine. Once I have those, then finding accessory drive, headers and the small stuff will start.
Stu-
Old 01-30-2012, 07:50 PM   #18
clinebarger
Re: 6L80E questions
Slow down killer, If you already have a E38 ECM (1st pic), And remove the TCM/Control Valve assembly. You can send both modules to Speartech for reprogramming. NO need to buy new.
I would like to idenify the ECM you have, The second pic is a E40 ECM..Later E67 ECMs look similar...3 plugs. The E38 ECM you need has 2 plugs.
If you need help removing/installing the TCM let me know.
clinebarger is offline   Reply With Quote
Old 01-31-2012, 08:44 AM   #19
olblue81
olblue81's Avatar
Re: 6L80E questions
I'll upload a pic of it later today.
Stu-
Old 02-01-2012, 01:17 PM   #20
olblue81
olblue81's Avatar
Re: 6L80E questions
This is the module that I have. Called a Transmission Module on the tag on it. The number on it is their stock number. I don't have an engine PCM yet.
I see on the Speartech site that they have this module as part of their kit. So I might return it to the salvage yard. But for $80, I just might keep it too.
Stu-
Old 02-01-2012, 07:31 PM   #21
clinebarger
Re: 6L80E questions
That is a TCM for a 4 speed auto.......4L60E/4L65E/4L70E/4L80E/4L85E.
The TCM/Contol Valve Assembly Is bolted to the Main valve body INSIDE the transmission on ALL 6 speed 6L80E/6L90E autos. Its not hard to remove with the right tools & keep everything clean.
I would return the TCM, It does no good on a 6 speed.
Old 02-02-2012, 02:11 PM   #22
olblue81
olblue81's Avatar
Re: 6L80E questions
Thanks for that.
I noticed on the Speartech site that there is an image shown for their 58x harness for 4L60E/4L70E/4L80E/6L80/6L90 trans that has this module in it. But I suppose that could be because the image might be of a 4L80E harness. I would post it here but unfortunately his site is flash and I can't copy it.
I haven't contacted Speartech yet since I was worried about finding an engine before finding a harness.
Stu-
