01-17-2012, 01:56 PM | #1 |
Porterbuilt C Notch question
I am seriously considering notching my 69. Just curious, how much room will the notch add? I have 6" drop springs right now and the axle tube is really close to the frame. (3" or so maybe?) Would I have enough room to add another 1" drop block on top of the arms? What is the depth of the bolt in notch? Any advise or lessons learned about measuring before I cut? I have heard to round off the corners of the cuts to keep the metal from cracking .. just things you guys might know to do. I have never installed one. I'm not afraid to, just looking for insight before I do it. Thanks.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
01-17-2012, 10:04 PM | #2 |
Re: Porterbuilt CNotch question
the porterbuilt c notch is very easy to install - if you have a plasma cutter and a drill it is a piece of cake. i have the mild notch on my truck and it went in very smoothly - i would get his shock relocator kit as well - it is very clean and nice looking - it shouls give you atleast an extra 2" of clearance and it comes with some nice bump stops.
if you have any more questions let me know Brian |
01-18-2012, 09:48 AM | #3 |
I don't have access to a plasma cutter, can it be cut with a grinder / disc ? I have a very powerful Makita disc grinder, realizing it will take a while longer that way.
01-18-2012, 11:12 AM | #4 | |
Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-18-2012, 12:27 PM | #5 |
thanks Nate! (Talked to you last night, this is Chad Coley)
Can't wait to get it and the shock bar. Do you have PB tshirts? XL Long Sleeve would be cool if you have any. I'll pay / add it to my order is fine. Thanks.
01-18-2012, 12:29 PM | #6 |
I used a grinding wheel on mine and it worked great. Easy to install and I second the shock relocator... Check out my build and you can see the pics I took. I made he mistake of not measuring twice. But it was fixable.
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
01-18-2012, 05:49 PM | #7 |
Chad we used a cutting wheel and it cut the frame super easy....not a hard job at all..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-19-2012, 09:40 AM | #8 |
Ok, cool. thanks for your help guys. I have been wanting to do this for a while and just broke down and PM'ed Nate. I wish I could get everything he makes for these trucks but my fun money just will not allow it right now. Major house projects, possibly International Adoption process, etc. Just doing things a little bit along as the $$ will allow, and trying not to flash the 'plastic' too much
Thanks for your help guys !! I'll post up some pics when I get it installed.
01-27-2016, 09:41 PM | #9 |
porterbuilts C-notches are a little confusing I read they have 3 levels. but on the web site only one shows...I want the mild step on you use for the touring package....whats it called?..or part number?
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
01-31-2016, 01:00 PM | #10 | |
67-72 parts collector,…
The other two are the Level 2 Touring notch and the Level 3 Extreme notch. I would call or email www.pbfab.com directly.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-31-2016 at 01:06 PM. |
01-31-2016, 01:05 PM | #11 |
Re: Porterbuilt C Notch question
I believe youi are looking for the Level 2 Touring notch,...
01-31-2016, 10:18 PM | #12 |
your right i want level 2 thank you
