Old 01-20-2012, 01:41 PM   #1
thankins93
smog pump
would it be smart or not smart to just take the belt off my smog pump? i really dont know to much about these smog pumps, the truck is still fairly new to me
1967 chevy stepside, 292 I6, 4 on the floor, 4.11 rear-end
http://www.youtube.com/user/thankins93?feature=mhum
MY 67!
http://67-72chevytrucks.com/vboard/s...d.php?t=446964
thankins93 is offline   Reply With Quote
Old 01-20-2012, 02:00 PM   #2
Rogue_Alphonse
Rogue_Alphonse's Avatar
Re: smog pump
You can.... Or eliminate the whole thing like I did. It doesn't affect the way the truck runs, but you have to swap manifolds
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 01-20-2012, 02:01 PM   #3
thankins93
Re: smog pump
and what are the pros and cons of "de-smoging" the motor?
MY 67!
Old 01-20-2012, 04:35 PM   #4
donut
donut's Avatar
Re: smog pump
Clean up the engine compartment. Less parts to break. Easier access to other items, (plugs, wires, etc.)
I just disconnected my smog pumps (2), and due to a manifold leak, ended up hacking off the spider web of AIR tubing, and replacing with headers. Headers were cheaper than replacing the exhaust manifolds (other than going to a junkyard.)
I was able to eliminate a bunch of vacuum lines, and replaced the rest that were rotted off.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 01-20-2012, 11:32 PM   #5
Rogue_Alphonse
Re: smog pump
Basically this, as well as that little bit of engine drag will be gone. Also, smog pumps [mainly GM ones] tend to just randomly seize up over time. PA emissions/inspection is pretty strict if you go to the wrong place and if they don't see any evidence of a smogger being there, they don't question it.
Basically the best thing to do is eliminate and forget.
Old 01-21-2012, 12:34 PM   #6
lilpoindexter
lilpoindexter's Avatar
Re: smog pump
If I didn't live in California, My smog pump would have been in a landfill a long time ago. It wasn't just the GM ones that seized up...pretty much any 70s car i've ever had, the smog pump seized up on it.
lilpoindexter is offline   Reply With Quote
Old 01-22-2012, 08:33 PM   #7
thankins93
Re: smog pump
what all would i have to take off to de-smog it correctly?
MY 67!
