Old 01-27-2012, 12:22 AM   #1
Livrat
Member #1049
Livrat's Avatar
71/72 gas pedal assemblies with T400 kickdown
One with wiring $40.00 shipped in CONUS SOLD
And one without wiring.. $35.00 shipped in CONUS ONE SOLD Several more available without wiring.. with or without deluxe pedal pad
(Sorry no cables available)
The wiring harnesses are available new from American Auto Wire for $18.00 each
http://shop.americanautowire.com/71-...wnharness.aspx
Livrat is offline   Reply With Quote
Old 01-27-2012, 08:14 AM   #2
OLEBEATER
OLEBEATER's Avatar
Re: 71/72 gas pedal assemblies with T400 kickdown
Do you have any accelerator cables and the bracket on carb?
OLEBEATER is offline   Reply With Quote
Old 01-27-2012, 11:17 AM   #3
joerocks
I'll get in line for the one without wiring.IM inbound
1992 Jeep Cherokee 4.0 AUTO
1972 C10 350/350
1971 C1500 350/350
1970 C20 396/400
joerocks is offline   Reply With Quote
Old 01-27-2012, 12:04 PM   #4
Livrat
Member #1049
Livrat's Avatar
Sorry no cables at all, I do have carb brackets that I would include with the pedal assembly.
Joe, the one without wiring is yours. Thank you
Old 01-27-2012, 02:45 PM   #5
OLEBEATER
OLEBEATER's Avatar
Thanks, but I just need a bracket for the carb.
Old 01-27-2012, 10:27 PM   #6
Livrat
Member #1049
Livrat's Avatar
PM me your mailing address and I will send you one. (its for a 4bbl Q-jet)
Old 01-28-2012, 10:29 AM   #7
OLEBEATER
OLEBEATER's Avatar
I'll need one for a 2bbl. Thanks for the kind gesture tho.
Old 01-28-2012, 12:21 PM   #8
Livrat
Member #1049
Livrat's Avatar
I may have one for a 2bbl, I'll take a look today
Old 01-29-2012, 10:35 AM   #9
OLEBEATER
OLEBEATER's Avatar
Thanks............
Old 01-29-2012, 12:57 PM   #10
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Mark, The one with wiring, is that complete with bracket for 4 BBL? If so I'll take it. Thx DP
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 01-29-2012, 01:25 PM   #11
Livrat
Member #1049
Livrat's Avatar
David, Yes I will include the carb bracket. (I didn't think of adding them to the original post). The only items I do not have are the bolts or cables
Old 01-29-2012, 01:48 PM   #12
D.PASSMORE
One of the First
D.PASSMORE's Avatar
That's OK, I have bolts for it. Cables, Are you referring to accel cable?
What I'm doing is gathering the parts to convert my 72 K20 to a TB400/205 setup that I have. I plan on setting the Tran/TC and leave the engine cradle in place. This set-up should work for it. If there is any other items neded, let me know. Thanks David
Old 01-29-2012, 02:00 PM   #13
Livrat
Member #1049
Livrat's Avatar
Yes, I was referring to the accelerator cable.
If you leave the engine cradle where it sits and put in a T400 it will move the transfer case and rear crossmember rearward, making driveline changes necessary,(A T400 is longer than the T350)
Also you you will need to relocate the 205 shifter as it will be moved rearward, I have an Advance adapter shifter handle relocator I will toss in for you.
Old 01-29-2012, 02:22 PM   #14
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Thanks Mark. Also, I think I will need a TB 400 auto tranmission linkage. Would you have some spare parts laying around? - - Give me a price...
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 01-29-2012, 05:04 PM   #15
Livrat
Member #1049
Livrat's Avatar
The linkage remains the same as the shift rod on the T400 is in the same location as your
T350, the difference between the two is the overall length of the trans.
Old 01-29-2012, 09:54 PM   #16
Livrat
Member #1049
Livrat's Avatar
I have one for 71/72 2bbl, It bolts to the coil bracket towers on the rear of the intake manifold,
If that is the one you need PM me your mailing address and I get it on the way..
Old 05-13-2012, 10:33 PM   #17
automagic67
I see this post is from January, but if you have any of the pedals left I will take one.
automagic67 is offline   Reply With Quote
Old 05-13-2012, 11:38 PM   #18
Livrat
Member #1049
Livrat's Avatar
Sorry, they are all gone.
