Carb and stock wire harness...
If i decide to go with a carb, how much of the original wiring harness is required. Being that my motor is 2006 and uses the pedal and tac, how does that work with the carb?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
Re: Carb and stock wire harness...
You need crank sensor, cam sensor, coils, ground, computer hot wire, diagnostic wire and water temp sensor. That's all that's left on mine after a buddy fixed the harness. I questioned the temp sensor and he stated that the computer acts funny without the temp sensor reading. He's done swaps on many cars and tune's ls based cars for a living. It works good.
Posted via Mobile Device |
Sorry I forgot to answer your other question. The tac module is for throttle control and DBW pedal. So in a carb setup they are not used.
Anyone know what the cost of an aftermarket harness is for carb versus fi?
you don't need any of the original ls harness..just a MSD box to run the coils. you don't need the DBW pedal either....Edelbrock sells a intake and msd kit specifically for carb'd ls motors...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
I know about this kit, i find it hard to believe i would need no harness to plug this into.....
just think, that intake and box, carb, and a eletric fuel pump and your ls motor is runnin.
i have already bought a fuel injected gas tank, in tank fuel injected pump and sending unit and a corvette filter/regulator...now what...
#10 | |
p.s. The msd box comes with its own harnnes. None of the factory harness is needed. Except for the short harness that is on the coil brackets.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
Guys I have both the MSD 6010 on the 1969 c10 and a carb setup ran by a factory computer and hacked harness on my 1955 chevy sedan. So you can pick up a used intake and use the factory harness, and have the fatory computer programmed. To me this was a cheaper alternative than the MSD box and is fully adjustable. The hacked harness has the same wires to hookup. Just my 2 cents
