Old 02-11-2012, 02:20 AM   #1
67 Burb
67 Burb's Avatar
95 LT1/4L60E into 67 Burb
This has probably been discussed before, but I have some questions.
I have a 95 Roadmaster with a LT1 and 4L60E that I want to yank out and drop into my 67 C10 Suburban. (Now with a 350/TH350)
What do I have to know before I start and just what problems will I have to watch for? Is it a fairly straight forward swap? Do I buy a wiring harness? Or just pull what I need from the Buick. Will I need an ECM reprogram?
Thanks.
Bob
67 Burb is offline   Reply With Quote
Old 02-11-2012, 07:57 PM   #2
69C-owner
Re: 95 LT1/4L60E into 67 Burb
I dont have any answers for you but I'm in for the ride, I have an LT1 and 4L60E I saved out of a 95 Roadmaster wagon
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
Old 02-11-2012, 09:10 PM   #3
67c10rustbuket
67c10rustbuket's Avatar
It will all bolt in, driveshaft may need to be changed depending on if you current one is the long or short tail TH350. I am doing a 97 vortec 350 swap using the complete wiring from a tahoe (not done im doing wiring on it now). an aftermarket harness is the easy route but I looked up the harness for mine and it is over $700 so Ill just do it the hard way. ECM program depends on what you modify if you keep the O2 sensors, EGR, Catalytic converters etc you should be able to use the stock ECM, some have a VATS vehicle anti theft system that may need to be eliminated by reprogramming. that and I beleive you will need different gauges for the electronic speedo VSS.
Heres one but its a 92 roadmaster drivetrain into a squarebody. lots of good wiring info in this thread!
http://67-72chevytrucks.com/vboard/s...d.php?t=356697
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 02-11-2012, 09:14 PM   #4
67c10rustbuket
Also check out lt1swap.com this site has lots of swap info for the LT1
Dan <---(my name)
Old 02-19-2012, 01:28 AM   #5
jiggityjoe87
I am also in the process of swapping an lt1 4l60e into my 70' burb. There are a few things you should keep in mind. There are a thousand small details that will take up a lot of time. Lt1swap.com is an invaluable tool that provides some much needed info. You will spend a good amount of time wiring up the car. Have you decided if you are going to have an in-tank fuel pump or inline. Btw if your a/c compressor is mounted on the lower ps you will have to notch the frame so it clears. There is a lot to go through I am only about 1/2 way through this swap and it boggles my mind sometimes the number of details
1970 C10 Burb' LT1 Swap in progress
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=446976
1964 Nova straight 6
1972 Nova 355 Hauls A$$
jiggityjoe87 is offline   Reply With Quote
Old 02-19-2012, 07:00 PM   #6
Wootdog
Wootdog's Avatar
You can also look up on hotrodlane.cc which is Street and Performance. I have one of their LT1/4L60E setups in my 67 C10 Stepside. They actually tell you what wiring you need and what you do not. I have had it in my 67 for over six years without any problems.
Kerry
1967 C10
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
2018 Durango RT
Wootdog is offline   Reply With Quote
