Old 02-19-2012, 11:49 PM   #1
MARIOS68PANEL
Active Member
MARIOS68PANEL's Avatar
another cluster question
My vac / tach gauge cluster has a tandom lock idiot light on the fuel gauge side. Please forgive a rookie question, but whats that for?
67 short step
71 Custom
MARIOS68PANEL is offline   Reply With Quote
Old 02-19-2012, 11:58 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: another cluster question
That would be out of a c-40 to c-60... same as the vac gauge.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-19-2012, 11:59 PM   #3
Livrat
Member #1049
Livrat's Avatar
Your cluster came out of a medium duty truck.. C40/C50/C60 or at least the fuel gauge did.
That light was to indicate the tandem axle was locked in.
Livrat is offline   Reply With Quote
Old 02-20-2012, 12:20 AM   #4
MARIOS68PANEL
Active Member
Ok, So its a waist to have it in my truck, At most I need a tach cluster.But could do with just the amp/oil setup
I am thinking I should sell this one and buy a gauge cluster that makes sence.
what should I ask for this one?
67 short step
71 Custom
Old 02-20-2012, 12:23 AM   #5
Livrat
Member #1049
Livrat's Avatar
that one should bring around $250 or so as is.. but all you need is to change the speedometer and add a tach lense and your good to go..
Old 02-20-2012, 12:26 AM   #6
MARIOS68PANEL
Active Member
Good Idea.
67 short step
71 Custom
Old 02-20-2012, 02:47 PM   #7
DaHos
DaHos's Avatar
Did you mean to say to change the FUEL gauge not speedo?
I too was wondering on swapping tandem/overspeed lens for the brake/temp unit, is the circuit set up to work with either?
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 02-20-2012, 03:41 PM   #8
Livrat
Member #1049
Livrat's Avatar
Oops!! My bad, yes I meant change the fuel gauge
