Old 02-20-2012, 01:54 AM   #1
Rick61
Repositioning the gas filler spout on a 73
Does anyone know if you can reposition the filler spout to accept the new gas pumps? I have a 73 custom delux and I want to re locate the filler spout to accept the new gas pumps. I was thinking an in bed fille spout. any ideas?
Rick61 is offline   Reply With Quote
Old 02-21-2012, 06:48 PM   #2
Number21
Number21's Avatar
Re: Repositioning the gas filler spout on a 73
What new gas pumps? All the pumps I've found work just fine in my '73....
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 02-21-2012, 07:48 PM   #3
Rick61
In CA we have high flow pumps that have a vacuum boot on them which causes quick shut offs or overflowing of gas. I think because of the angle of the filler spout.
Old 02-21-2012, 07:56 PM   #4
76stepsidechevy
Does your filler neck have the large opening ?
76stepsidechevy is offline   Reply With Quote
Old 02-21-2012, 08:07 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
I wonder if you could make some kind of pipe/tube that would go into the filler neck, then you could insert the gas nozzle into it, then you could hold it all at the right angles so gas wont go spewing everywhere. Some small exhaust pipe and a piece of angled radiator hose may do the trick. Might be an easy way out instead of modifying the truck.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
