Wheel size
Will I need to narrow the rear end og n 84 silverado with stock diferential if I put some 22x12...thnx in advance
"NO BAGS JUST PLAIN LOW" |
Re: Wheel size
Anyone...
Square
Re: Wheel size
I think you will, I have 22x10 and they barely fit. but I am not 100% sure
Squarebody Syndicate |
Re: Wheel size
Do urs tuck in?cuz im plannin on a static drop n not sure uf they have clearance
Square
Re: Wheel size
yeah my truck lays frame. but when it had the 7 inch drop in the rear the tires almost rubbed the inside of the inner fender.
Re: Wheel size
o ok...did u cut in the inner fender of the bed or u diidnt mess with that
Re: Wheel size
How much static drop? What tire size?
My bet is you'll need to slightly enlarge the wheel-tubs (mini-tubs) for a 12" wheel w/anything more than 5" of rear drop.
Re: Wheel size
Mayb 7/11...n I really dont kno of the tires yet...still debatin
Re: Wheel size
7" front 'static' drop? Yikes.... That's also a heck of a difference front to rear (normally it's a 2" difference). 11" rear drop will definitely require modifications to the bed and/or rear housing depending on how much wheel lip you want.
Re: Wheel size
Yea...im gettin ready to spend some cash on the modifications ima need lol
Re: Wheel size
7" drop in the front with 22" you might have a ruff time making turns.......If you havent already, put 22" on before you drop it anymore and see where your at
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
Re: Wheel size
Its gonna b a 20 22 combo
#13 |
Re: Wheel size
my 20's rubbed when i would make fast or real sharp turns with a 4" drop
#14 |
Re: Wheel size
U think ima really need bags
#15 | |
Re: Wheel size
#16 |
Re: Wheel size
what do you got on there now for rims and tires and what is done to the front to lower it now and what were yo thinking of doing to lowering it more
| Bookmarks |
