Can anyone tell me the extent on making the window swap from the 52 vent window to the one piece window in the 50 model chevy. And what all I need to do the swap. Do they make conversion kits or do you have to custom fab it yourself? Or do I just need to swap the whole door out? Any info would be highly appreciated.
Posted via Mobile Device |
![]() Join Date: Mar 2007
Re: Door window swap from 52 vent to 50 solid window
I suggest doing a search first. This topic has been covered many times with pics and advice. Look around awhile, you will find all your answers....
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
for some constructive advice...
There is no kit. You'd have to cut out and weld in all of the internals to make this swap. It would probably be much easier, possibly cheaper to just swap out the entire door (depending on where you are with your project).
1953 GMC 1/2 ton long bed Original 228 I6 with a Hydramatic Auto Tranny Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649 ![]() |
I've got at least three pair of 47/50 doors that have had the windows, regulators and front channel removed from them before I got them. The last pair I got for 30.00 for the pair when not as nice doors with all the pieces had a 75.00 ea asking price at the same swap meet.
I don't have photos of the inside of the doors to show the differences but here is a link that after scrolling down the page bit you can see the differences between the 47/50 regulator and the 51/54 Regulator http://www.chevsofthe40s.com/search....le+Site+Search To do it right you also need the steel frame that goes around the glass and you need the track for the rollers. |
Thanks guys I really appreciate the help
look at this build...pg 3
