Old 02-23-2012, 04:47 PM   #1
84_chevy
Hub/Rotors
Hello
I'm looking for some help/advise. I'm trying to remove the front hub/rotors off my 84 4X4 but I don't have the correct special socket for the job. I went to the local parts store and they did have a socket that looked like it might work but the sales guy was not sure if it was the right size or not and neither am I. What they had was a 40mm socket with 4 prongs, is this correct? If this is not the correct tool what size is it and do I need to go to a dealer to find it or should I be able to find something off the shelf?
Secondly if any of you would offer some advice on replacing the front hubs such as torque setting/ tips and trick or any unforeseen problem I might run into that would be great. This is my first attempt at messing around with hubs and bearing so any help would be appreciated.
84_chevy is offline   Reply With Quote
Old 02-23-2012, 04:55 PM   #2
Stoney
Farm Truck
Stoney's Avatar
Re: Hub/Rotors
I went to Advance Auto parts and rented the whole set, 79.95 you get the hole 79.95 back, if you buy the brake rotors from them. It wasn't 40mm, It was like 1 15/16 4 prong.
Not a metric.
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 02-23-2012, 06:44 PM   #3
munice
regular everyday normal guy
munice's Avatar
Re: Hub/Rotors
I'd hit up another parts store, most of those special sockets say what vehicles they fit, (mine fits fords and some dodges aswell) Ive got the socket for front hubs and and one for the full floating rears, the ID for my front hub socket was 2" and 3/16ths i just checked them both but neither has any actual sizing on it.
-Andrew-
1987 Chevrolet V10 SM465 NP208
w/ '89 454 dual plane hi-rise 750cfm 1407
w/ '86 10b /14b
new motor on the way:
GM#990 heads
25cc speed pro pistons
COMP XE 274h
crane gold rollers
munice is offline   Reply With Quote
Old 02-23-2012, 07:09 PM   #4
TDS-MN
Re: Hub/Rotors
I also don't know the exact size, but am guessing it's not a metric. What i do know is, that 4-prong socket will fit in there very snug, please take care to get it just right. I would not think that it would be something that you would need to get at a dealer, but your availability in canada may be different than mine. My local parts store has them on the shelf, but I was lucky enough to have a friend that owned one already, I didn't see the need to purchase, since I don't see this as a job that the average owner is going to get into that often.
I utilized a Haynes manual when we re-built my front axle in december. Don't recall much as far as torque settings, but there were a couple instances when we did use the torque wrench. Most of the inner workings of the hub itself are not required to be that tight. In my case, we had removed axle shafts as well, not sure how deep into the front end you are planning on going with your project.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Old 02-23-2012, 08:45 PM   #5
84_chevy
Re: Hub/Rotors
At this point I'm just trying to get the rotors off to see if they can be re-machined, if they can be. One of the rotors has grooves in it at least a sixteenth deep so I might have to replace them for new ones which brings me to my second problem.
My truck has seen many owners and I believe its been molested to death over its lifetime. When I check the VIN numbers it comes up as a 2wd but what I have is a 4X4 so I'm assuming the body was swapped out from the original body that probable rusted away long ago. The problem I have now is to figure out what year and what type of front end I have on the truck so I can find the correct parts, right now I'm only guessing.
Old 02-24-2012, 02:21 AM   #6
Your41Plague12
Your41Plague12's Avatar
Re: Hub/Rotors
Your grille is an 83-84, which is correct. Looks like everything should work just fine.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
