02-24-2012, 08:40 PM | #1 |
62 with a power booster
I know this has been gone over and over... but i havn't seen anyone try to put a clutch master under the dash.There is about 8 inches of space on the right side of the pedal bracket between the rod lever and firewall. Thinking about welding a sturdy bracket on the pedal assembly frame.Then bolt a wildwood master,of course the rod would have to be much shorter,but have the same action. could even use a remote reservior routed to outside firewall.I'm just not crazy about a power booster bracket sticking way out and trying to cram a clutch master behind it. any thoughts or ideas??
02-25-2012, 12:22 AM | #2 |
60-66 Nut
Re: 62 with a power booster
There is an option besides the ones that have the clutch master behind the booster.....
http://www.67-72chevytrucks.com/vboa...d.php?t=362375
02-25-2012, 01:30 PM | #3 |
very clever design...maybe considering this. Thnx for the response.
02-25-2012, 06:57 PM | #4 |
Senior Enthusiast
I haven’t seen a clutch master mounted behind the firewall either, but don’t see any reason it wouldn’t work with some creative engineering. Here’s what mine looks like with a Wilwood master mounted on the passenger side of the booster:
This picture shows the inside linkage: Doesn’t seem like it would take much effort to fabricate the bracket you described and move the cylinder inside the cab. I would definitely want to use a remote reservoir. The risk of spillage on the carpet and poor ergonomics would make filling, checking. and bleeding very uncomfortable.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
