02-27-2012, 02:15 PM | #1 |
Intake manifold issue.
I have a 350 performance engine in my 65. When I bought it, it had a Holley 650 double pumper carb on it. I recently put a Edelbrock 600 cfm performer carb on it to try and get a couple more gallons out of it. I have a Weiand single plane intake, My question is should I go ahead and pay for a new performer dual plane manifold or am I just throwing money away? All in all it runs pretty good now butidle is not always smooth until it realy warms up, I have heard that single planes verses dual are a little different, should I pay the 150.00 or just stick with the Weiand? any input is greatly appreciated. Thanks
02-27-2012, 02:23 PM | #2 |
Re: Intake manifold issue.
I have run both and the dual planes seem to have better manners at and off idle. They seem to be a little more daily driver friendly.
And I'm pretty sure you can pick up a good used for less than the $150. How bout it members, anybody willing to part with one for a good cause?
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
02-27-2012, 02:37 PM | #3 |
Who Me?
I would think there would be much difference.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
02-27-2012, 02:47 PM | #4 |
I put a vacum gauge on it and it seems to have the right amount of vacum. What would the differences be? Any gas mileage change or is it just a torque verses rpm thing?
02-27-2012, 04:00 PM | #5 |
It depends on what you want you engine to do! "IF" you want a drag racing screamer then a single plane is the way to go! "IF" with want a "burn across the intersection" engine then a dual plane is the right choice. It's a matter of physics ...it takes longer for a volume of air/gas to reach it's peak going down a "big hole" then it does a "small hole" (i.e. dual plane) ...SO bottom line is dual plane is "quicker", but single plane is "faster"! ... Vacuum reading won't change between manifolds at idle.
02-27-2012, 04:13 PM | #6 |
The single plane you have, being a performance manifold, doesn't have a heat crossover which is the reason it has to warm up a bit. A good dual plane will have better low end torque and street performance, and most likely have a heat crossover unless you go with the RPM model.
02-27-2012, 07:17 PM | #7 |
I am going to bite the bullit and get a new performer 2701 manifold to go with my 600 cfm carb.
02-27-2012, 07:43 PM | #8 |
Just here to tinker
I agree with above. Dual plane for torque, single plane for top end.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
02-27-2012, 08:01 PM | #9 |
If you really want good milage I would find a Quadrajet with an electric choke , jet the primaries up 3 or 4 numbers and like the others said get a manifold with an exhaust crossover,the performer with the q jet pattern would be a winner.... 2101 ..........
02-27-2012, 09:58 PM | #10 |
x2
02-27-2012, 10:22 PM | #11 |
Senior Enthusiast
If you want to save gas grab a strip kit and start leaning that new carb out. It took me quite a few changes and road tests to dial mine in. Edelbrock carbs are setup very rich from the factory.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
02-28-2012, 12:17 AM | #12 |
I experimented with jetting for a year as I drove my 73 c10 180 miles to tech school ,tried a few different carbs and went from 8 mpg with an old 4jet rochester , to 12 miles per gallon with a qjet jetted with 74's on the primaries it always felt dead jetted at 68 so we kept bumping it up , got more responsive and better milage ..
02-28-2012, 02:07 AM | #13 |
60-66 Nut
I agree that dual plane intake will be better for a street driven engine. Here is a used one at a good prive, if you don't mind doing a little cleaning.
http://www.67-72chevytrucks.com/vboa...d.php?t=511076 If you do decide to go new, consider a Performer EPS. It is basically a little more refined Performer, to squeeze just a little more TQ and HP. Plus you won't need the adapter plate to bolt a square bore carb on it, since it has a square bore carb pad. http://www.summitracing.com/parts/EDL-2701/
02-28-2012, 06:59 AM | #14 |
Markeb01 , if you don't mind me asking what did you finnaly do (Jet wise) to dial your edelbrock in? Jets and metering rods, would appreciate the info, thanks
02-28-2012, 07:05 PM | #15 | |
Don't waste money buying a new standard Performer manifold. The EPS is a great piece for the money and is a square bore so no adapters. |
02-29-2012, 01:55 AM | #16 |
60-66 Nut
I might add that the Performer EPS can also be had with the front oil fill tube, if that is something that interests you.
