Floor Shifter
I am getting ready to put a floor shifter in my 1965 c10 but I don't know how tall I want it.
Does anybody have any pictures of theirs? I am thinking 23-30" range. |
Registered Loser
Re: Floor Shifter
I put a B&M Unimatic in mine.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
![]() Join Date: Oct 2009
Re: Floor Shifter
If buying an aftermarket, I recommend the 16"-ish ones. You can see the pics and the part numebrs of mine if it is what you're looking for. 16-16.5" is about the tallest I've seen without going to the Count Dragula rat rod sticks that scrape the roof. Anyway, this thread has more than you're looking for - but it does have the stick info and pictures for reference/comparison to help you decide. Hope it helps. http://67-72chevytrucks.com/vboard/s...d.php?t=482069
EDIT: Oops - just noticed it sounds like you want a tall!!! one, anyway - maybe the pics here will give you an idea how much taller to look for. |
Re: Floor Shifter
What's goin on with that intake manifold that I think I'm seein in yer first pic there, creep....?
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
Senior Enthusiast
Re: Floor Shifter
What transmission are you running?
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Re: Floor Shifter
Old pic...23 inch Gennie shifter...interior finished with bench seat and it looks nicer. will need to post pics later..
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
Registered Loser
Re: Floor Shifter
That's a scoop.
Re: Floor Shifter
16" Lokar shifter
---------------------------------------------- 1966 Chevy C10 frame off resto (In progress) 1966 GTO Numbers matching original 1989 Toyota Pickup (Tonka) resto 2002 HD FLSTC 2000 HD FLSTC 1996 Ninja ZX11 ![]() ![]() |
![]() Join Date: Sep 2009
Re: Floor Shifter
23 inch lokar on low hump
Re: Floor Shifter
Re: Floor Shifter
I'm running a 700r4. Gimmy I really like the looks of yours. Looks great!
Posted via Mobile Device |
Senior Enthusiast
Re: Floor Shifter
Here’s what mine looked like many years ago when it had a TH350. Both shifters came through the original SM420 hole in the floor pan after about ¼” of trimming:
The first 3 are a 23” Lokar with a high hump floor: ![]() ![]() ![]() This is after I swapped in a 16” Gennie Shifter: ![]()
#13 |
Re: Floor Shifter
gimmy I been looking for a steering wheel like yours...I always liked the old skool grant looking steering wheels....who makes it and where did you find yours? Did you have to install a steering wheel adapter for that steering column you have? Im in the process of installing a hot rod universal GM tilt steering column with a 9 bolt steering wheel adapter on my truck..cant believe the steering wheels cost just as much as what I payed for the steering column..
#14 | |
Re: Floor Shifter
#15 |
Re: Floor Shifter
gimmy thanks for the info...
