2wd vs 4wd
this 2wd truck sees alot of off road it never gets stuck but sometimes it gets in a jam it rarely hits posi when i need it but ive never had it stuck i just want it to perform better when its off the road do they have any 2wd lift kits? what size tires should i run? also this truck hauls alot of scrap metal.(it just how i make my money) but it runs 600-700 pound loads every now and then and barely squats it has brand new suspension and it rides really rough i dont mind it i just wonder why its like that. and that last pic is 668 pounds of steel on the back of the truck the inline 6 hauled it around just fine
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor) 350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator. |
Re: 2wd vs 4wd
new exhaust
Re: 2wd vs 4wd
I had the same issue with my 67 shortbed stepside. It was 1/2ton with a 250 inline and 3 on the tree with 3.73 rear end . I put 32in. super swampers on the back and it made a big difference. I also hauled a lot of scrap. So better tires in the rear is what i would do if its just a traction issue.
I cant say for sure but a body lift might work or do a google search for baja or prerunner kit for your truck. Last edited by Chucks; 04-07-2012 at 11:59 PM. Reason: more info |
Re: 2wd vs 4wd
Fabtech use to make a 2wd lift kit years ago you might find one used on ebay.
Canadian Trucker
Re: 2wd vs 4wd
I keep throwing this thread around when I see 2wd lift questions, some one should make it a sticky.
http://67-72chevytrucks.com/vboard/s...d.php?t=447061 There isn't really a lift kit available for the 73-87 trucks anymore, this guy lifted his with an 88-98 lift kit. Other then this, if you want the truck to perform better off road, you need to get a new posi, or even better a locker. If money's no issue an electric or air locker is best.
![]() 2020 Silverado Trail Boss - 6.2/10spd |
Re: 2wd vs 4wd
wow i really didnt think a lift for that new of a year would work. i LOVE those wheels!
Re: 2wd vs 4wd
rough country lifts make some 2wd kits for chevys, i put one on a two wheel drive 78 once. the site is www.roughcountry.com may have to call the kit they have listed is for 82-87 . i know they make them for 2wd, lift and bigger tires you will be fine
Re: 2wd vs 4wd
blocks in the back hd springs in the front
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
Re: 2wd vs 4wd
i have a 86 c20 that i use the hell out of and i go through anything with the bfg t/a 235/65/16 E and i go snow mud even down the beach where i live. and a posi is in my future too. i am also looking at the air ride kits in summit for better load leveing.
| Bookmarks |
