Garage Queen Material
295/50/15's on the rear?
i've decided that i'm not getting 255/60's all around. i want some meat in the back.
what i'm wondering is will a 295/50 tuck with a 6" drop on 8.5" wheels with i "think" about 4" back spacing. will a 295 be to wide for a 8.5" rim? |
#2 | |
Re: 295/50/15's on the rear?
Personally though, 255/45 18 would look better
the 295/50/15's are only .4" shorter than teh 255/60/15's . and thats fine, since my back end is a little higher anyway. the sidewall is only .2" shorter than the 255/60's too.
BeWarE tHe eViL CrAnkTOe!
Technically...it really is to wide for it but if you dont care about wear/danger/ contact patch or bulging sidewalls go for it.
![]() I know that tons do it and I dont care....its flat out too wide of a tire for that wheel...ask low84...he probably hates mounting tires like that on wheels that size. And the way the tire has to bend around the wheel..you end up with less tire contact patch on the road than you would with a 255 on the wheel.
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
Yeah...look at me, I've got a 255 on a 9½" rim
#6 | |
And you are how old eric?? lol...nevermind we can tell haha
Riptide has the right setup. 295 on a 10" wheel is perfect and looks much better while taking advantage of the full contact patch
to tell you the truth, i'm not sure exactly what size my rims are. i do know the 275/60/15's fit on there perfect and do not look to wide or to skinny, but pretty much flush.
anyways. would a 305 tuck? what size rim would be best for a tire that size. i'm asking about it for a set of 18's btw. |
Just stop screwin around and get some 335's!!
#10 | |
YEP!
but I think Eric is confused....I think he is driving G's Tire Fryin machine and needs a 26" wide slick on the back for traction!! lol
has anyone measured to see how much offset to the inside our trucks will except? , I have a 10" rim w/ 325-50's on mine with a 3.5 backspaceing , and to get them in the wheelwell all the way i would need aproxamatley a 4.5 backspacing. I have about 1/2" of sidewall out of the wheelwell.
just wondering 85
#13 |
yeah i definatly agree with dave. a 295/50 needs a 9.5 or 10 inch wheel to fit right, and get the benefits fromt the wider tire. but before you go stuffin some meats under there stuff some power under the hood. i'd much rather have to much motor for my tires than too much tire for my motor. i'm eventually gonna be running 15x7's on front with 215/70/15's and 15x10's on rear with 295/50/15's. those tire are the same hight but the back one is a hella lot wider than the front. but i stil don't think those will keep me planted
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#14 | |
#15 |
I have the following:
Front: 15x8 Centerline Telstar w/ 4" BS w/ 295/50/r15's Rear: 15x10 Centerline Telstar w/ 4.5" BS w/ 295/50/r15's A 295/50/r15 is kind of wide for an 8" wheel. They do fit and the sides do budge slightly. The tire shops I have talked with said there is no problems with mounting that tire on an 8" wide wheel. I tried to find different tires to get away from the slight budge, but didn’t have luck. I wanted to keep the back tires, 295/50/r15’s, and just change the front to something not as wide. But very few companies made tires in both sizes so I could have matching front and back. That is why I kept the 295/50/r15’s all around. These tires and wheels (front and back) will NOT tuck up into the wheel wells. The edge of the tires are right at the wheel well lip. Hope that helps some.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
#16 |
My set up:
Front- 20X8.5 w/4.75"bs running 255/35/20 Rear- 20X10 w/5"bs running 295/40/20 I too reccomend a 10" rim for anything over 275 wide. The set up I run works with bags with over an inch clearance on both sides of the rear wells.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction
#17 |
took some pics of my 325's , outside and inside. theres alot of room to get the under there.
#18 |
and
#19 |
85GMC, do you have the wheel specs (width/b.space)?
#20 |
15-10's with a 3.5 backspaceing , they are series 55 engles
#21 |
BAD BOW-Silverado XST
The 255 will hold that the 305 pretty good. They hold mine really good when they are hot. If they are cold you can for get it. The 305 will light'em up!
Without a 700R4 the 305 probably will not smoke anything bigger than the 275. :p
#22 | |
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
#23 |
mmmm....Rye and Coke
I'm running 275/60s in my 305 and it looks great, and amazingly it can still get the tires to chirp, with the cracked manifolds and all
#24 |
LED King
I have 275/60s as well and they do work well for the 305s. I tempararily have 225/75 on and they spin like no one's business! My 305 can burn! Yesss!
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
#25 |
I am running 15x10 5 inch BS...295/50/15 and they tuck into my wheel well about an inch. I am running 15x7 in front with 255/60. The combo looks pretty good. I wish I had some pics to show.
1984 C10 SWB Custom Frame Blow Through Carb Single Turbo Hope to be on the road by Summer 2018 1967 C10 CST LWB 327/PG Original Running Driving Future Project |
| Bookmarks |
